This forum is for Tips and Tricks. Please do not post any questions in this forum. It is only for information.
The following was compiled by a fellow member themuzic (aka Johnny Geib). Johhny also runs the Home Studio Trainer website (homestudiotrainer.com), providing one/one training for Studio One and other presonus products.
This list should be considered "Un-Official", as it was not compiled by Presonus directly. There may/may not be features not listed here. We will try our best to keep this updated as things are added/deleted from the feature set. I am also attaching a text doc of the same listing for download.
CS18 WORKING FEATURES:
Faders, Mute, Solo, Select, Pan
Faders control DAW faders
Busses are in “Mix Masters”
FX Busses are in “Returns”
“Mute” mutes DAW channels
“Solo” solos DAW channels
Pan is controlled by 16 encoder knobs at the top and can also be controlled by encoder under the Touchscreen for currently selected track.
Select button color matches Studio One channel color
Track Channel Mode (mono\stereo)
Selecting a track and then clicking the Stereo "Link" button will change the channel mode between mono and stereo.
Scribble strip
Shows:
channel name
Automation mode
Pan
Control Link parameter for Plugins
Record arm
Hold "Option" and press channel "Select" to toggle record arm on/off per channel. When in record arm the scribble strip will display a large "R" to indicate an armed channel
Channel layer navigation
Channels 1-16, 17-32, and so on. Press Shift and channel layer to go to channels 65-128. Press CTRL and channel layer to go to channels 129-192.
(Not implemented) Groups button used for mixer "scenes". Select a scene to hide channels not in the scene. Option to add a scene/group, page to show selected group with exit and delete buttons.
FX/Aux Returns button show FX channels
Mix Masters button shows buses
Group Masters button shows output channels
Group Masters Button (under fader selectors)
Any Cue mixes created in Studio One can be controlled, independently, by a fader when the "Group Masters" button is selected. (This is only active when the output in the Studio One Output matrix has the "Cue" box checked)
Flex Fader
Pressing “Edit” in “Assign” section will assign currently selected channel to the Flex Fader
Deselecting and pressing "Edit" again will release the Flex Fader.
This will also work with tracks that are grouped together in Studio One.
Mix navigation
Press Main Mix button to have the main L/R mix on faders
Press Mix button 1 - 8 once to bring the associated send mix to the faders. Mix number corresponds with Send slot numbering from top to bottom
Press Mix button 9 - 16 once to bring the associated cue mix to the faders. Mix number 9 - 16 corresponds with Cue Mix slot from top to bottom
Automation modes
Uses Mute group buttons.
All On = All Read
1 = Read
2 = Touch
3 = Latch
4 = Write
5 = All Read
6 = All Touch
7 = All Latch
8 = none
Transport
Uses Transport buttons as labeled
Modifiers for additional funcitons
“Option” engaged - Stop is “Fast Forward;” RTZ is “Rewind”
“Ctrl” engaged - Stop is “Next Marker;” RTZ is “Prev Marker”
Solo clear
Clear and channels that are “Solo” enabled
FX Inserts/Sends
Tapping FX on Touchscreen opens list of Inserts or Sends for selected channel
Inserts - shows top down list of plugins on channel
Sends - shows top down list of sends on channel
Tapping plugin in Inserts list will map plugin parameters to 16 encoders
Parameter names show in 16 mini screens per channel
Parameter value shows in Touchscreen and via meter bridge
Tapping again dismisses plugin from computer screen and unlinks plugin parameters from encoders
Tapping Sends will select it.
Send level controlled by encoder below touchscreen
Jog Function
The knob under the touch screen can be used as a "Jog" when enabled from the Markers button and then hitting "JOG" at the top of the screen.
Control Link Mode
De-activating all buttons to the left of the "Selected Channel" meters, activates the Fat Channel for Control Link assigning of the knobs and buttons.
Foot Switch
Make sure the CS18 is in DAW mode
Select "System"
Now go to Footswitch Mode
Press it and you will now see a drop down
If you can not see the DAW options, select the last option and then select again.
You will now see 2 DAW options "DAW Rec/Start" and "DAW Drop Markers"
Select the one you need and then press home.
CS18-StudioOne-WorkingFeatures.txt
(3.74 KiB) Downloaded 107 times
by Mac Money on Thu May 25, 2017 5:59 pm
Thanks!
George Ware
StudioOne v3.5.6 Pro 64bit
Pro-Tools 12.5 64bit
Waves DigiGrid IOS
PreSonus CS18ai & BCR2000 Control Surface
Intel 6 Core i7 3.2Ghz.
Windows 10 Professional 64bit.
Arturia KeyLab-61
URS, Waves Mercury+Studio Classics, EMI, Sonnox Oxford, Antares, Plugin Alliance, Nomad Factory,TL Labs, Serato, Massey, Komplete Ultimate 11, Arturia V-Collection 6, Lounge Lizard 4, Korg Collection, UVI Falcon, P&M VIP, Audio Damage, Melodyne Studio, VocAlign, Eventide, IL Vocodex, IL GrossBeat, Artillery 2, OPX, Softube and IKM Total Studio Max.
