279 postsPage 14 of 14
1 ... 10, 11, 12, 13, 14
"Bypass All" in Macro Controls:
You can add Bypass All function to Macro Contorls:
Welcome to my Facebook page : My music for movies and games : My psy-trance and psy-chill music
Support me. Buy my music if you like it: nimbitmusic : bandcamp
System Specifications:
Windows 10 Pro (x64) 1909, Studio One 4.6.2 (x64), MB ASRock X370 Taichi, 32 Gb Ram - Samsung M378A2K43BB1-CRC DDR4-2400 (1200 МГц), AMD Ryzen 7 2700X, 3974 MHz, SSD M.2 970 EVO for system, M.2, SATA SSD and other SATA HDD, Video - Sapphire Nitro 580, soundcard Roland VS-100, Acer XR382CQK
by Zirrex on Wed Jun 17, 2015 7:27 pm
This is simple Macros can help you open BUS and Show Sources Tracks with maximum verical Zoom + Zoom in Loop.
Add Keyboard Shortcuts to use this Macros: Console - Toggle Sources
Show Track and Zoom to Loop.studioonemacro
(482 Bytes) Downloaded 1438 times
by Lawrence on Wed Jun 24, 2015 9:27 pm
Here's a new one I stumbled on today by accident...
1. Open an audio project.
2. Select all of the clips and right click "Copy"
3. Now go paste that into Notepad or similar.
What you'll see is nicely formed XML of all of the audio regions.
by Lawrence on Mon Jun 29, 2015 1:23 pm
Custom Drum Maps
Now that we have the Chorder plugin, you can use it to remap midi notes for drums, to have input of Pitch A output Pitch B. Below C1 (Kick) is actually triggering C#2 (Crash). Create your custom maps configured any way you want and save them as Chorder presets.
by snb1 on Thu Sep 03, 2015 3:02 am
You can drag and drop plugins onto Impact's Pads to create an insert for that channel.
Studio One Pro 6.6 64 bit, macOS Monterey 12.6, 14" MacBook Pro M1 (2021),16gb ram, 512 SSD, 8-core CPU
SkipNo Beet
by snb1 on Mon Oct 05, 2015 2:49 pm
Switching between two different sets of plugins.
1.) Pull up the plugins you want to include in your [Shift] + V (toggle optional views) key command. Exclude all other windows like mixer, browser, Track List ex. because these will get included. Once your plugins are up, hit your [Toggle optional view) key command.
2.) Next pull up another set of plugins. These will be under your [V] (Toggle floating windows) key command. Once your plugins are up, hit your key command.
3.) Now you can switch between the two sets of plugins. WARNING** You have to use the same key command to bring up and take away the plugins before switching to the different set. If you bring up your first set of pluigns and try to go directly to your other set of plugins by hitting the other key command, it will override the settings and you will have to set it up again. So you will have to remember what set of plugins belong to what key command.
SkipNo Beet
by snb1 on Mon Oct 05, 2015 5:34 pm
You can add, combine, and replace instruments directly inside the piano roll.
SkipNo Beet
by Zirrex on Sun Dec 06, 2015 3:08 pm
snb1 wroteSwitching between two different sets of plugins.
I use this option for Master FX, or for Analyzer in Master section.
by jso on Thu Dec 10, 2015 2:23 pm
Copy FX Chain
Studio One Pro 3.3.1
Windows 8.1
by Lawrence on Thu Dec 10, 2015 10:56 pm
Toggle Between Two Different FX Chains (alternate method)
Setup two FX chains with any plugin that can mute the audio paths (I'm using ReaJS for the mute plugins) . Set the mutes to inverted bypasses on a macro button. Ciick the button or your hardware button or use an automation envelope in arrange to toggle between them.
Each mute plugin (Chain 1 & Chain 2) is just a straight away gain plugin at infinity gain, which stops the audio signal when it's not bypassed. You could use Mixtools for that if it went to infinity, but it doesn't. Use the new gain sliders in the routing screen to balance their apparent levels for A/B.
You can also manually toggle them in arrange once the envelope for that macro button is exposed...
by jso on Thu Mar 03, 2016 3:50 pm
Automation Clips:
Credit goes to Xbitz (or anyone else who pointed this out before.)
From channel within Multi Instrument
From Channel for whole Multi Instrument
Here's Xbitz video that gave me the idea:
Windows 8.1
by Funkybot on Mon Jan 16, 2017 5:15 pm
Lawrence wroteSTUDIO ONE - Any verson - Presets in the browser
The browser is an often underutilized resource, using it for things other than loops and plugins and all the more obvious things. It will also allow directly accessing things like drum maps and color presets, without opening any of the dialog windows associated with those things... like the "Options" dialog for changing color sets.
Make browser tabs to all of those things for easy access...
Lawrence (or anyone else),
Does clicking and dragging Color Schemes still work or is there some kind of extra trick required? I've added the UserPresets\Color Schemes folder to the Files section of the S1 Browser, but I get the "No Smoking Circle" whenever I try to drag and drop one from the browser onto the S1 GUI as shown in the gif.
Here's a gif showing what happens on my PC:
by VladimirOstrava on Thu Feb 16, 2017 3:02 pm
Some loops, for example drum loops from looploft.com can be tricky and because of missing tempo information will not follow song tempo. Here is quick and easy fix.
Intel Core i5, Win 10, Studio One Professional 6, RME USBD, RC500, ADL600, Sceptre S6, Eris 4.5, FaderPort 8, Monitor Station 2, UA 610, UA Satellite 2, Focusrite Liquid Saffire 56, Melodyne Editor 2, Native Instruments Komplete 10, M-Audio Axiom 25, Keystation 49e
by VladimirOstrava on Mon Feb 27, 2017 3:48 pm
Moog Mother 32 is a great little synth. And it works with Studio One like a charm. See how to set it up here.
by Funkybot on Tue Aug 01, 2017 6:28 pm
Someone posted this in the Feature Request forums (in response to an open request of mine) and I didn't know it existed, so I figured I'd add it here. Thanks to JustinMeyer for the heads up.
Some Browser Shortcuts (browser window needs to be in focus):
Alt+Up Arrow: Closes all open browser folders
Alt+Left Arrow: Closes the current folder
This is very handy after you've found yourself with a ton of open plugin folders and want to get back to some semblence of sanity without a ton of clicking.
by axxessdenied on Sun Sep 30, 2018 8:02 am
i7-7700k, Asus Z270-A, Windows 10 Pro, TI Chipset firewire controller, Firestudio Project w/ 6pin > 6pin cable ( Retired ), RME Babyface Pro, Studio One 3.5+, Softube Console 1, Faderport
Noise Implant - Auditory and Visual Stimulation
by snb1 on Mon Jan 07, 2019 7:05 pm
You're able to add plugins to your master channel by dragging and dropping plugins over the top of the master volume in the arrangement window. You're also able to double click just above the master volume to bring up the plugins that's on the master channel. You're not able to double click to hide the plugins though.
SkipNo Beet
by snb1 on Mon Jan 07, 2019 7:13 pm
You can add plugins directly into the Track List.
SkipNo Beet
by snb1 on Mon Jan 07, 2019 7:21 pm
You can rearrange your tracks and add tracks to folders/buses using both the Track List and the tracks in the arrangement window interchangeably by dragging and dropping.
SkipNo Beet
