LMike
Navigation & View Here are some potentially useful unmapped Navigation commands... ![]() And these are no brainers to map to call your Mixer Scenes and your Arrange Scenes .... ![]()
House | Dubstep by Thedmncproject
i7 920 | W8.1 x64 | 12GB RAM | Samson | Studio One Pro v2 | Echo Audio Fire 4 | Nvidia GTX 480 |
LMike
Duplication My personal favorite new edit command ALT + D, Duplicate & Insert (ripple) ... ![]()
taoyoyo
Some more nice tips... just setup the Track/Console Scene shortcuts to Modifiers + NumKeys!
Melodyne ARA integration in Studio One Version 2
Studio One v2 - In depth ARA (Audio Random Access) Tech Talk
Studio One v2 - Melodyne Pitch correction
Editing Audio Audio Analysis Adjust Pitch Tranpose Notes e.t.c
Studio One v2 - Comping
Take Management Layer Auditioning Lanes Ranges
Studio One v2 - Transient Detection and Editing
Audio Bend Tool Detecting Transients Adjusting timing of individual transients Audio Quantization and Slicing Groove Extraction Working with Multi track Drums Beat Correction
Studio One v2 - Track Management
Track List Folder Tracks Track Layers Automation Lanes Track re - ordering Store Presets Detachable Audio and MIDI Editors
Studio One v2 - Project Page Enhancements
DDP Export PQ Editing Loudness Analysis
Studio One v2 - Open Air
If you cannot find any presets for the Open Air Reverb in Studio One v2 please make sure you log in to your user account, download and install the "Studio One Impulse Responses" content file. After doing so when you next start up Studio One 2, check the presets for the Open Air Reverb and you should now see a very large collection of presets for this plugin...
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts (Introduction)
This is a follow up on LMikes previous posts covering this topic on this thread. He most helpfully identified many unassigned keyboard shortcuts in Studio One v2. This is in no way a PreSonus omission or problem, quite the opposite IMO as there are *many* excellent and intuitive keyboard shortcuts already assigned to get you going in S1 v2. I think the unassigned keyboard shortcuts are simply there to be discovered and used by users who are interested in that kind of workflow (to whatever level). So moving on there are many Unassigned Keyboard shortcuts that will surely be of interest to many users for different reasons (as a result of their different work flows). The tips will not cover every single one but suggest a nice collection in each area of operation in Studio One v2 as a list. Who might this interest... 1.One who may have no need at all for a certain group of short cuts but might see another set as essential. 2. Another user who might not use Keyboard shortcuts that much but might now look to set up a nice small or large set of go to Keyboard short cuts specific to their own workflow after reading these tips. 3. Power users of Studio One or even more casual users who may simply not be aware that there are many ways to work with S1 using Keyboard Shortcuts. Some aspects of new Features like Audio Bend and the Track List for example do not have assigned Keyboard Shortcuts and are waiting for users to assign their own. 4. Those who are curious about new ways to work with Studio One that are not immediately obvious. Moving on to part one...
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 1 (Remove)
When using Keyboard shortcuts in any DAW you want some way to manage them quickly and easily. What about easily finding and removing existing shortcut assignments so that they can used elsewhere? Go to Studio One > Options... > General > Keyboard Shortcuts Under "Applicatons" go to "Extensions" (Unassigned) Now click on the "Enter Key" field on the right hand side to select it and enter "2" (an already assigned key for "Toolbar - Tool 2") A "Show" command will appear. This is because the key is already assigned. Click on the "Show" command to see where exactly the conflicting assignment is. At this point the "Remove" button now becomes active. Should you wish to click on it, the Keyboard combination or key you require will now be free for another assignment specific to your own preferences and workflow
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 2
It would be next to impossible for me to pick a set of Keyboard shortcuts that would fit anyone's workflow exactly so these are just suggestions that may be of interest. These are currently (as of the time of the original post) unassigned... Audio 1. Detect Transients 2. Export Audioloop 3. Split at bend markers 4. Remove Bend Markers 5. Send to new Sample One 6. Strip Silence Automation 1. Manage Parameters 2. Remove Current Parameter 3. Show / Hide 4. Show device 5. Write Browser 1. New folder 2. New Tab 3. Rename File 4. Show in Explorer Finder Console 1. Hide Channel 2. Hide Sources 3. Toggle Sources
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 3
This set of unassigned Keyboard Shortcuts include other areas of usage within Studio One that many users will come across regularly... Edit, Event and File Edit 1.History 2.Move to Origin Event 1.Mute Events 2.Quantize on Track 3.Rename Events 4.Split at Grid 5.Transpose Events down 6.Transpose Events Up 7.Unmute Events File 1.Clear Recent Files 2.Close All 3.New 4.Rename 5.Restore Version 6.Revert 7.Save To new Folder
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 4
Instrument Parts and Media are part of many S1 users workflow... Gadgets 1.Soundcloud client Help Check For updates Keyboard Shortcuts Instrument Parts Explode Pitches to Tracks Export Musicloop Export Parts to MIDI file Remove Part Automation Separate Shared Copies Marker Delete Media Convert Files Copy External Files Locate File Locate Missing Files Remove Unused Files Select on Track Show Media Folder in Explorer/Finder
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 5
Another unassigned set covering Musical functions, Presets and working with Projects (Mastering) Musical Functions Delete Double Notes Delete Short Notes Freeze Quantize Humanize Humanize Less Length Quantize End Restore Velocity Stretch Transpose Velocity Presets Export Preset Import Preset Re-Index Presets Replace Preset Store Preset Store as Default Preset Update Plug-Ins Project Burn Audio CD Detect Loudness Digital Release Disable Track Enable Track Import File Locate Missing Devices Make DDP Image Make Image Project Setup Remove Track Update Mastering Files
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 6
Recording is part of the foundation of any DAW... Quantize Clear Pattern Select Base Record Functions Undo All Undo Last Loop Record Mode Input Quantize Loop Record Mix Loop Record Note Erase Loop Record Note Repeat Loop Record Takes Record Mode Overdub Record Mode Replace Record Takes to Layers
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 7
Tempo and a huge collection for Tracks... Tempo Delete Insert Track Activate Layer Add Audio Track (mono) Add Audio Track (stereo) Add Automation Track Add Bus for Selected Tracks Add Folder Track Add Instrument Track Add Layer Add Tracks for all Inputs Audio Input follows Selection Collapse All Tracks Duplicate Duplicate Layer Duplicate with Events Edit Expand Envelopes Expand Layers Hide Instrument Input follows Selection Pack Folder Remove Layer Rename Group Rename Layer Show in Console Solo Layer Solo follows Selection Transform to Audio Track Transform to Instrument Track Transform to Realtime Audio Transform to Rendered Audio
Studio One v2 Mini Series - Unassigned Keyboard Shortcuts Part 8
This is the final set. Your specific preference and choice of features that you want to assign will differ from the next person. Just give some consideration to these features as assigning even a few of those listed in this mini series could add something very useful to your existing workflow. Transport Autopunch In Autopunch Out Cursor follows Edit Position Locate Selection End Metronome Setup Play from Loop Start Record Return to Start on Stop Rewind Set Loop End Set Loop Start Shift Loop Shift Loop Backwards Stop Toggle Start Play Pause View Audio Bend Fit Timeline to Contents Info View MIDI Monitor Messages Open Markertrack Open Tempotrack Performance Monitor Quantize Reset Window Positions Show Project Show Song Strip Silence Time Display Track List Transfers Zoom Data Zoom In Data Zoom Out Restore Zoom State Track Height 1 Track Height 2 Track Height 3 Track Height 4 Track Height 5 Track Height 6 Zoom Full Horizontally Zoom Selected Track
