Page 4 of 6
Re: Melodyne 4: Worldclass Tempo Mapping for Studio One!
Posted: Sun Jan 17, 2016 7:35 pm
by jpettit
David Mood wrotejpettit wroteTo enable tempo editing you have to click the wrench.(note assignment mode)
Thanks Jeff.
In the video by Celemony they say you need to be in Edit mode, that's why I missed that.
Maybe the standalone version (which they are using in the video) works a bit different in that respect.
Sorry for the stupid question: doesn't drawing in tempo changes by hand kinda miss the whole point about this tempo mapping feature?
Isn't this all about aligning the tempo in the DAW to a tempo of a performance?
Dave the issue was you were watching their video vs my video.
They did all their new videos using the standalone (which has more buttons/options)
Take a look at the PDF it has the whole story.
Posted: Sun Jan 17, 2016 7:46 pm
by David Mood
jpettit wroteTake a look at the PDF it has the whole story.
I will definitely do that, many thanks for making it!
Re: Melodyne 4: Worldclass Tempo Mapping for Studio One is finally here!
Posted: Mon Jan 18, 2016 12:51 am
by jpettit
psusername wrotejpettit wroteFunkybot wroteThis is definitely a case of RTFM, but can anyone tell me if there's a quick and easy way to set the bar and beat in Melodyne and have that transient line up and if so, how?
Don't quite know what you are referred to with transient. In Melodyne it would be a blob you are aligning to.
Are you asking how to set beat one in S1 or how to set beat one in M4?
If M4 you drag the tempo bar to the beat representing the first sound.
It will by default move in quarter note steps. (The whole ruler will move left or right).
If it lines up then you are set.
If it does not ( which is common) Then:
b. If it will not snap to the correct downbeat position use this procedure to fine tune it:
i. Click the segment BPM drop down and select "enter subdivision"
ii. Type 16 subdivisions and slide the tempo first down beat line over to align with the first downbeat.
iii. (Optionally) return the subdivision number back to its original value
Now the beat one marker will move in 1/16th steps.
Match it up with the first real beat one measure in the blobs.
This is the first time I have tried this and I'm not sure if I am doing this correctly, but it seemed to work (I did get it to repeat). I am also using Melodyne studio as a plugin vs stand alone as suggested in some of their videos. To do the tempo mapping, I followed your steps and found that I needed to set the track in Studio One to "Follow." If I didn't do that, the timing (tempo mapping) of the track would change to a faster tempo. Once I set the track to follow, when I clicked back from the tempo map screen (by clicking the edit icon to the left of the wrench tool) I could click and drag the temp map from the track area in Studio One up into the tempo map area and the track was now mapped within Studio One.
I need to try the temp mapping as stand alone as they suggest in the videos (I was mapping to a stereo mixdown track) since that would incorporate the timing of all the tracks and be more accurate. Overall I find the tool amazing coming from those days of fighting with a TEAC 3304
gs
I just installed the Demo of Studio and noticed it has Import Tempo so you should be able to import the tempo map you made in the stand alone version.
Posted: Mon Jan 18, 2016 5:07 pm
by RochesterDude
the Melodyne tempo map that needs to be dragged into Studio One:
1. where do I find the Melodyne tempo map
2. Do I really drag it onto the Studio One tempo track or is it some other type of operation that gets it into the Stidio One tempo track?
Thanks for the help
Posted: Mon Jan 18, 2016 5:17 pm
by jpettit
Watch the video I show you clearly had to do it there it's in the process Melodyne track and you drag that to the temple track
Posted: Mon Jan 18, 2016 5:31 pm
by RochesterDude
Yes, sorry for being slow to reply, after I posted this a did a google search for the video and found yours. It explained everything I needed. Thanks for your time putting the video up. appreciate it.
Posted: Mon Jan 18, 2016 6:12 pm
by jpettit
It is in the first post
Posted: Sat Jan 23, 2016 10:00 pm
by dgkenney
Here's another quick and dirty example of Melodyne 4 tempo mapping. A friend dropped by to lay down some violin tracks. To warm up we played a little Irish reel. Lots of tempo changes - some intended some rust and lack of practice. No click track, just 1,2,3,4 go.
In any event, Melodyne did a respectable job given the jumps from 105 to 130 bpm. Just added a 4 bar drum loop from RMX to simulate an Irish drum. A little ragged in some areas, no doubt, but not bad for instantaneous. Totally automatic. If I was doing this for real I would tweak it some but I'm impressed with M4
https://soundcloud.com/dgkenney/st-anne-reel/s-tH0fG
Posted: Sat Jan 23, 2016 10:49 pm
by jpettit
Dan did you use the tempo mapping to just tighten up the song or did you add the bohren as a loop?
Posted: Sat Jan 23, 2016 11:51 pm
by dgkenney
Just added the loop. Mapped the song as is. Just a violin and guitar free from.
Edit: let me be more specific.
Recorded with 2 mics
Mixed down to stereo file and insert as track in song.
Melodyne'd to establish tempo map
Copied melodyned track to S1 tempo track
Added instrument track with Stylus RMX
Picked semi-appropriate drum sound
Dragged 4 bar midi clip to instrument track - duplicated to length of song
That's all foks
Posted: Sun Jan 24, 2016 1:05 am
by jpettit
Posted: Wed Jan 27, 2016 3:53 pm
by jpettit
Moving to "Tip and Tricks forum" for easier reference access.
Posted: Sat Jan 30, 2016 7:57 pm
by Beachboy
Jeff,
Thanks for the tutorials - Much appreciated.
Not sure if I missed it in the posts but does the algorithm used in Melodyne 4 (Studio) have any effect on tempo detection?
Posted: Sat Jan 30, 2016 8:21 pm
by jpettit
Yes
The two polyphonic ones are the most accurate.
If you're just detecting drums then it will default to a drum algorithm.
There is an option in that case under the temple menu to use a advanced temple detection algorithm.
Posted: Sat Jan 30, 2016 8:38 pm
by Beachboy
jpettit wroteYes
OK - Thanks!
Posted: Sun Jan 31, 2016 5:17 pm
by garryknight
Jeff, I've just gone through your Melodyne tutorials again after upgrading to Assistant and I thought they were as comprehensive and excellently produced and delivered as I did the first time of watching. Thanks for making them.
As an aside, I was wondering what that song is that you used as a demo at 25 seconds into the third video. I don't recognise it, and it's quite a while since I listened to that style of music, but I do like it.
Posted: Mon Feb 01, 2016 10:29 am
by jpettit
Here is the first Tutorial Video on basic tempo mapping.
It should help you with a majority of cases. I am working on more difficult mapping and tempo mapping MIDI performances next.
Please make sure you check the Original Post. The complete training package is always updated there.
Posted: Mon Feb 01, 2016 10:45 am
by dgkenney
Nice job on the vid...and who doesn't love the Rev. Al Green
Posted: Mon Feb 01, 2016 12:22 pm
by dgkenney
Interesting. Just watched the Melodyne site's videos on ARA integration in both S1 and Sonar. In the S1 video, tempo mapping is featured as a function of the ARA integration. In the Sonar video it is not displayed, so I am assuming tempo mapping is not available as a ARA function.
Posted: Mon Feb 01, 2016 12:38 pm
by jpettit
No the issue is Cakewalk's 30 year old ( never dusted off) tempo window cica 1985.
They have no way to import/drag the tempo map.
I guess the CTO has recognized the gap and will support it in a future update.
I have to decide if they are going to do it right and toss the old tempo window and replace it with a modern tempo track. This will determine if I upgrade my subscription.
