How do I change the key of an entire, already recorded song, like a karaoke machine does, ya know, from the key of F to say G or A. Any key. Or while I'm halfway through recording the song and I find the key it's in is just too low for example, can I change the KEY of everything I have recorded so far on an unfinished piece instead of starting all over?
That depends.....are you recording MIDI or audio tracks?? In the future we can assist you better if you will provide a bit more info......if you will post your system specs (see my sig), we will be better able to trouble shoot any future problems. Without knowing what type of pc you're running, what OS you're using etc....we can't often recommend a "simple fix"
Ditto with Cristofes' advice to make a signature*.
For audio: "Transpose" (in the Inspector). See pages 67-68 in the Manual. You can also use Melodyne (see manual, pg 95). However I've found if you approach changing the pitch 3 - 4 steps or more with audio clips, artifacts can/may show up. I'd guess if you're working with midi, you'd already know.
Users browsing this forum: Demious, iliravdyli and 66 guests
