I upgraded to 6.6 a few days ago and everything was fine. Then I packed up my laptop and went to band practice on Thursday night and my MIDI controller wouldn't work with some songs, but was fine with others. I worked out that it was only working with older songs, which I had not saved since the upgrade. I had a second controller there so it set it up and it wouldn't work, either. The next morning, after I set my laptop up at home again, the controller I have at home wasn't working with any of our songs.
So that was three different controllers, from three different vendors - Korg, Arturia and Donner - that wouldn't work with Studio One. However, they all worked fine with half-a-dozen standalone synths I have installed and with my old DAW, Orion. I checked the settings and whichever controller is plugged in seems to be recognised by Studio One - no little yellow triangle - but it still says "not connected". I tried restarting Studio One and restarting my computer and all the rest of it, to no avail. Eventually, however, I solved the problem... SOLUTION: Remove the controller from the list and add it back in. It's a relatively pain-free fix but I left it until last. You should try it first if you have some the same problem.
NOVAkILL : Asus RoG Flow Z13, Core i9, 16GB RAM, Win11 | EVO 16 | Studio One | bx_oberhausen, GR-8, JP6K, Union, Hexeract, Olga, TRK-01, SEM, BA-1, Thorn, Prestige, Spire, Legend-HZ, ANA-2, VG Iron 2 | Uno Pro, Rocket.
Just to add to this, it seems that the issue was a bit more complex than this. What I eventually worked out was that, somehow, Studio One had saved these songs, all pieces created recently, with INPUT set to "None" on every track. I had to go in and manually set them to "ALL", or to the device I wanted them to respond to, to make them work properly.
