import .multisample to SampleOne XT from Bitwig exported .multisample
Posted: Tue Oct 31, 2023 8:30 am
by scottmiles
Has anyone successfully imported a .multisample from Bitwig into SampleOne XT? Is it possible? It works in the other direction--with Bitwig I can open a .multisample exported from SampleOne. But not the other way around. If I try to import a Bitwig .multisample it says it imported the preset. But the samples are not imported. On top of that, nothing seems editable at that point (e.g., I can't drop in the samples to see if the xml data was imported and could be applied). Importing/exporting .multisample in both directions would make the .dawproject import/export workflow even better (which has been working well for me).
