hello all, do you know if there is an idea to produce a native clipper plugin for S1?
Thanx G |
Hi G,
There's no idea on any upcoming Studio One features. Sometimes a day of two prior to a release (rarely known when), Presonus might drop a video or sizzle image on what is coming or rare release date. No hint of such a clipper offering.
Hi and welcome to this forum.
Clipping comes in many flavours. For guitar/keyboard distortion/overdrive/foldback style clipping you can look at the RedlightDist and Pedalbord plugins, for 'shave the peaks' clipping you can look at the Limiter plugin, and for digital 'clipping' (distortion) Bitcrusher can be used. Real digital clipping (as in overdriving the AD-converter) is just nasty, unpredictable and bad. Interfaces become better and better in avoiding it altogether. So for that kind of clipping you're on your own I guess |
My favorite clipper is Clipper from Softube, I know it’s not the answer to you question just wanted to chime in.
paliottofrancesco wrotemartinchilds2 wroteThe Soft Clip option within Limiter 2 does operate as a clipper. I just confirmed myself by running a sine wave through it and viewing the resulting wave in the Scope plugin. For the purposes of some detail towards bit crushing for clipping, check out this link from Logic. https://support.apple.com/ar-sa/guide/logicpro/lgcef1a8f27c/mac#:~:text=Bitcrusher%20parameters,behavior%20of%20all%20three%20modes. Bit crusher with Studio One https://pcaudiolabs.com/how-to-use-presonus-bitcrusher-in-studio-one-4/ That said, it depends on if you're looking to get some distortion by reducing the bit depth. This is far from the earlier request where you were looking to reduce transient peaks. Only the good advice of using a limiter didn't satisfy I think it was your needs because you weren't looking to brick wall the limiting. This becomes more of a specific need by the user, because a good limiter doesn't have to be brick wall at all. One simply sets the threashold, ceiling, release and input values to achieve the limiting needed. Think of the opposite. A compressor doesn't just sustain signals. The same use of on-board controls of a compressor can vary everything from a kick, to cymbals dancing, to ....you get the picture. All too often, subject matter in the forum can morph, so given what you're asking, try the bit crusher, or run it in series with a limiter. I'd avoid the bit crusher altogether, but I'm not imposing any answer as much as just trying to clarify your asking what the bit crusher will do for your clip needs. JMO, but I'd really try to explain what drum peaks and hopefully what frequencies you're looking to alter/cut/crush/distort. That helps others offer the best advise. A bit crusher in general would be crude when looking to clip. Then again, crude may be what you're after. Unless the details are provided, we could be all over this topic, and not have the real need, understood. I'll end by what Switchback stated earlier and that is "clipping comes in many flavors". Hope the bit crush info adds some possibilities for you. Should be fun trying!
Users browsing this forum: Lokeyfly and 9 guests
