Would any of you like to recommend a good way to create a nice natural sounding vocal? I know that it depends on the vocal itself and your personal preference. So, this may be hard to answer. But, I'd still like to hear what those of you with a lot of experience are doing.
Thus far, I have used the "Male Vocal" Insert and the "Room Reverb" Send (set at "Large Hall'). That seemed like a nice generic starting point. However, there are 5 different male vocal presets. There are also several Reverb presets and I noted that Joe Gilder (PreSonus) uses "Rev PLATE-140". Then there are a million adjustments that can be made after you start with a preset. |
stephenrachlin wroteWould any of you like to recommend a good way to create a nice natural sounding vocal? I know that it depends on the vocal itself and your personal preference. So, this may be hard to answer. But, I'd still like to hear what those of you with a lot of experience are doing. As a voiceover artist - this is really on one of things I do all the time:) My recipe: 1. Great mike (large condenser always first choice) - warmed up and ready to go. 2. Great pre-amp (or a channel on the audio interface) - sent clean to S1 3. An initial compressor (your choice) on the S1 mic insert (while recording) to tame the vocal peaks on the way in (I use the Waves Scheps Omni Channel on everything here) 4. Once a vocal is comped, edited and complete in S1 - then (and only then) will I begin post processing as needed (ranging from more comp to delays, verbs etc) but I always work with a super dry vocal to start. Cheers VP
stephenrachlin wroteWould any of you like to recommend a good way to create a nice natural sounding vocal? Finding the right mic for your voice might take some time, I bought and used different mics over the years, really loved Sputnik for a long time. Same issue with preamps, buy one try it for 6 months or whatever then sell it and get a different one until you find what you're looking for. I actually stopped using my quality preamp and started using a UAD interface with a mac mini which uses a software classic preamp and I'm liking it. So the preamp gets printed on the recording. I was going to say that getting the right sound is more than finding the right preset, but then I just rebuffed my own point. Getting ahold of a good mic is a good starting place. Good to put your specs in your signature, click below in my signature.
I can second what was already mentioned above regarding only a compressor when recording.
After that I usually start with EQ, De-Esser, reverb, saturation, and parallel compression to beef things up. Once that is done, there is usually still some volume automation/clip gain that will happen to fine tune things. I used Waves VocalRider in the past, but honestly, it gives me mixed feelings. Even with processing I often tend to manually fine tune S's, F's, P's - plosives in general to get a more natural sound. Zooming in, and pulling down a "p" that stands out can make a big difference, just don't over do it or it will sound like a speech disorder Also, you need to pay attention to how the vocal itself sits in the mix with other instruments. You want to make the appropriate room for it to sit well. I know that some go to lengths to do this (for example, side chaining the vocal to a multiband compressor on an instrument bus) - and although that can help, I tend to stick to a more classic approach of compression and EQing myself. There is really no rule book.. try different things, see what works for you. And when you change your vocalist, you have to change it up again anyway
Tacman7 wrotestephenrachlin wroteWould any of you like to recommend a good way to create a nice natural sounding vocal? Tacman, are you using the Modeling Mic system UAD as? Sounds like it. Did you have to purchase a special mic for this? If any Mic will do that would be killer as i have UAD system cards in my computer (actually in an Xmac mini server) Please advice what is working. This very well could be an great option for folks that have UAD already |
No, I didn't know they had a modeling mic. I see Antelope Audio puts modeling mics with their interfaces, been wanting to try that whole system, one of these days...
UAD models hardware and whatever you plug in it will sound pretty close to using the hardware. I guess a modeling mic would be neutral and not add anything to the sound of the hardware. I don't know how much I buy into some of that, but willing to try. I use a WA-251 that I've had for a few years, with the UA-610 plugin that works well for my voice. If you find a plugin you want to print to the recording when you record it just put it in the input section of the console in S1. Guess you would have the UAD console that has a slot for that maybe...
Users browsing this forum: musicchamber, strumpy_strudel, Trucky and 67 guests
