Can I take a series of Tom samples from an original sample in SampleOne, (i.e. pitched samples of Toms on C, E, G, B, D, F, A, C) and spread it out over maybe 8 pads in Impact? I've been overwhelmed with all the things you can do btwn those 2 apps that I've got paralysis of analysis.
I don't see why not. I'm not in front of my computer but you might be able to drag them across. Just be sure to save the presets you make, and/or what song they're in. If nothing else, save them and build up patches, and banks.
As to moving over actual presets, that I'm not sure, as it may be native to the instrument only. I'd have to take a look. I'm always looking for original sounds, but saving As and reloading the sample later in Impulse XT sounds like it should work. Sample One XT is outstanding. I sample some of my acoustic instruments into it. I think it's time to look into buying the Presence XT Editor which would make sample layering very easy between Sample One XT and Presence XT
Just a little nitpicking in advance: SampleOne and Impact are instruments within Studio One, not apps. But never mind, this contributes very little to the point of your question
Regarding using SampleOne samples in Impact: Absolutely, just drag the samples over to the pads in Impact XT, it's as easy as that. The only thing you need to pay attention to is that you need to pin one of the instrument windows to be able to have both of them open at the same time. I made a video on almost the same topic: Copying samples between two instances of Impact XT. Dragging samples between SampleOne and Impact works basically the same. I hope that helps!
Lukas Ruschitzka
AWESOME!! Sorry for the offense. 1,000 lashings. I KNEW there was another proper word, but I was having a brain fart.
So, I just watched the video, and I'm SEVERELY STOKED!! Now, am I correct in assuming that I can open an instance of SampleOne, or Presence, OR another 3rd Party INSTRUMENT, and simply drag /drop? If so, I GUARANTEE A HUGE CHOCO COOKIE! |
Hello Jazzundso,
*UNSOLVED* I just tried the copying from 1 Impact instance to another, with several variations, and I watched the video very carefully 3-4Xs, but I just couldn't make it happen the way you did in the video. I made sure there weren't any Cntrl, or other buttons to push, I tapped on the Pin in the 1st instance. I tried several different pads, I tried different kits on the 2nd one, but nothing worked. What am I doing wrong? |
So, I just watched the video, and I'm SEVERELY STOKED!! Now, am I correct in assuming that I can open an instance of SampleOne, or Presence, OR another 3rd Party INSTRUMENT, and simply drag /drop? If so, I GUARANTEE A HUGE CHOCO COOKIE! It will work only with certain PreSonus instruments since drag'n'drop of audio files between 3rd-party plug-ins is not supported. georgelea wroteHello Jazzundso, That's weird. I usually try things out before posting, so here too. I had absolutely no problems dragging samples from SampleOne to Impact. Oh okay, you were talking about two Impact XT instances in your last post - I just realized that while re-reading. For Impact XT -> Impact XT you have to hold Ctrl (if you're on Mac it's probably Cmd). I did not say this in the video and only displayed the modifier key as an overlay - maybe that was the problem in your case. One thing that might be useful to know is the Info View. It always shows you additional functions available via modifier keys depending on the control you're currently hovering with the mouse. This works even for instruments (again, only Studio One internal instruments).
Lukas Ruschitzka
Lukas Ruschitzka
