Hey Gang, is there an easy way to take a sample from Presence, or SampleOne and convert, or copy it so I can use it for Impact, or am I missing something?
There's a lot of ways to do that.
You might try... Create a midi event with one note in it, get it to sound like you want in Presence, then bounce it. Ctrl/B. Then drag it to a pad from the browser. You could put the same note on several pads then re pitch them on the pad, the pad can change them on the fly. https://s1manual.presonus.com/#Built-In ... 257C_____4 Alternately you could draw in a chromatic scale then chop it up and bounce each piece separately so you would be pitching it before taking it to Impact. Maybe try each way a little bit and see which way seems better. There's a limit to how much you can re pitch audio but when you use midi notes that's not a worry. Good to put your specs in your signature, click below in my signature.
Users browsing this forum: No registered users and 67 guests
