Dear Forum. As a newcomer to home recording, I am unable to get direct routing (specifically via headphones from channel output 3 on the interface or 7/8) of my microphones (1 vocal mic and 7 "drum" mics) using my Focusrite 18i20 3rd Gen. Neither via Cue mix in the SEND settings in the mixer, nor otherwise.
Possibly it is also due to the settings in Focusrite Control, however I followed relevant Youtube video tutorials and it still doesn't work. Can anyone help me here; I also posted screenshots of my settings in Studio one and focusrite control here in the thread if that helps in finding the problem. |
Welcome to the Forum!
Cue mixes in Studio One "Output" settings require stereo pairs. You also need to click to add checkmarks in the Cue Mix column to enable them as shown here: The Cue Mixes will be added here as shown:
Thank you for your answer!
But i still got the same issue. I plugged the drum headphones into output 3 and do not hear the sound of my drumset microphones...? This is so frustrating because for instance i hear the click or sound of the pc (youtube etc.). To be honest i think I'm literally just "one click" away to get the problem solved but can't figure out if it is an issue in FOCUSRITE Control or studio 1. Any ideas? THX in advance |
Post screenshots of what you have now after setting cue mixes up the way I told you.
Be sure to configure Focusrite Control so it routes the I/O to match the settings in Studio One.
Click and drag up the horizontal line above "Cue Mix" in the Mix view to show the cue mixes.
Then post a screenshot that should now show both of your cue mixes.
Your I/O setup in Studio One for cue mixes looks correct.
Don't forget that cue mixes in Studio One are stereo so it should be Outputs 3/4. Plug cables from there on your Focusrite 18i20 to your headphone amplifier. Is the cue mix for Outputs 7/8 working? If so, as a test try using Outputs 5/6 or another pair instead of Outputs 3/4. I'm not familiar with Focusrite Control so I'd recommend submitting a support ticket to Focusrite for assistance with routing settings for your Focusrite 18i20.
Did you submit a support ticket to Focusrite for assistance with Focusrite Control routing settings for your Focusrite 18i20?
Users browsing this forum: DarkBlueSky and 71 guests
