Hi
I have Sudio one 6.1 latest version I have Native instruments as an additional DAW -KOMPLETE 14 COLLECTORS EDITION The problem I have is the Size of the DAWs in Presonus and unless I increase my Windows settings to 300% I can hardly read the non Presonus instruments even on a 60inch TV which I use as a monitor - any suggestions would be welcome - see attached screenshot 1. Studo one Presence instrument vs 2. Native Instruments DAW - Absynth Stereo If I open the DAW outside of Studio one it sis decent size to read and use Windows 11 Pro 64 bit 64Gig Ram 60 Inch TV Monitor |
What resolution is your TV set to?
andrewbailey2 wrote I have Native instruments as an additional DAW -KOMPLETE 14 COLLECTORS EDITION The problem I have is the Size of the DAWs in Presonus and unless I increase my Windows settings to 300% I can hardly read the non Presonus instruments even on a 60inch TV which I use as a monitor - any suggestions would be welcome Andrew Your TV MUST have (and be set to) PC Mode for starters - not any other mode that your TV offers. Dig around in the settings for your TV to find this. And most importantly - once in PC mode - the resolution must be set to standard HD (1920x1080) I am using a 2009 Samsung 40-inch LCD here and have been for years. AND I use the video display from my CPU (No third-party video card) and everything works great. Windows 10 Pro text size is 100% and all UIs from Studio One to all my Komplete 14 ULT instruments are normal. FWIW - even though "4K" remains the most popular "selling" feature of today's monitors and TV - that standard is pushed to consumers based on a movie/video standpoint where more pixels look much sharper. However - a 4K Blu-ray or Netflix 4K movie stream is NOT the same as a software UI - which I still believe that (in general) - all software vendors (Presonus, Native Instruments etc) - continue to code their apps to behave "normally" in standard HD (1920x1080) resolution - which sets a "minimum" standard baseline requirement for anyone buying a typical computer monitor these days. If your onscreen items are super tiny - I can tell you right now that your TV resolution is way too high and nothing you can do settings wise (in Windows or otherwise) will make everything look good until every single vendor out there is coding their UIs to work natively (AND normally) in 4K standard resolution. VP
They have been asking for a bigger window since 2013 that I found.
Some plugins have an adjustment that is hard to find so I looked but haven't found it yet. Don't think it's there. I use a 43" TV with 1920 x 1080 and 100% scaling. The thing is still small, I would make it bigger if I could. EZkeys is supposed to get an update cause it's about the same size. I don't find it hard to use, I can't run 4k if I wanted to, if I could it would be way smaller. Instruments have grown over the years.
Trucky wroteWhat resolution is your TV set to? 3840 x 2160 200% scale I see some other replies so I will play around with my settings |
Vocalpoint wroteandrewbailey2 wrote I have Native instruments as an additional DAW -KOMPLETE 14 COLLECTORS EDITION The problem I have is the Size of the DAWs in Presonus and unless I increase my Windows settings to 300% I can hardly read the non Presonus instruments even on a 60inch TV which I use as a monitor - any suggestions would be welcome Thanks I will play around with my TV & PC settings as PC settings are currently 3840 x 2160 200% scale I see some other replies so I will play around with my settings |
Sadly after all this time Native Instruments plugins aren't scalable. It's unbelievable they still haven't sorted this.
Users browsing this forum: patrickviens and 70 guests
