Hi all
I have added shortcuts to my Faderport and Android app to do the following: * Add Scene (Works) * New Scene (Works) * Previous Scene (Works) * Rename Scene (Works) However, the Update Scene does not seem to work. If I use the mouse to select a scene and update directly from within Studio One, that works perfectly. But if I move around a few scenes on the Faderport or App, adjust some faders and then click Update Scene it does not always work. If I then select the scene manually, and then hit Update Scene on either the FP or App it works! Am I missing something? Thank you Mike |
Further to this, I have found the following:
If you manually select a scene using the mouse, then use the FB or App to make changes and update the scene, this works. However, if you have clicked inside the Scenes section, so it only have a small blue box, then make any changes within the app and attempt to update scene, it does not work. |
Users browsing this forum: bartbalint and 68 guests
