The playback of Solo Take of audio recordings broke down. The sound is lost 1 second after moving the Solo from one Take to another. Normally it plays only on the second attempt of playback. Also in the 6th version, "Solo follows Selection" does not work correctly. Moving Up and Down arrows sometimes works, sometimes not, the Solo stops responding to movement between Takes. It is treated by restarting the "Solo follows Selection" checkbox, but after a while it stops working again. (MacBook M1Pro)
DJ Avadhuta wroteThe playback of Solo Take of audio recordings broke down. The sound is lost 1 second after moving the Solo from one Take to another. Normally it plays only on the second attempt of playback. Also in the 6th version, "Solo follows Selection" does not work correctly. Moving Up and Down arrows sometimes works, sometimes not, the Solo stops responding to movement between Takes. It is treated by restarting the "Solo follows Selection" checkbox, but after a while it stops working again. (MacBook M1Pro) Please.update.your signature with your specs. Are your audio interface drivers and firmware up to date?
At first I had a laptop with Windows 10 and Studio One 4, AudioBox USB 96, wich worked very good.
I bought a new laptop with Windows 11 and tried to put Studio One 4 on it but there was no sound and all the amps were gone. I bought Studio One 6 Artist and at first I had no sound but that problem was resolved, but I saw that once again all the amps and cabinets in Studio one 6 were gone. So now I havent played guitar for 2 weeks because I just can't use the software. My question is obiously how to solve it to have once again amps and cabinets that are simply missing now. I réally hope someone have an awnser. Greetings, S. Schulting from the Netherlands |
So you are running the latest studio one 4 (or 6) update? Also the latest windows updates?
You've downloaded the latest universal control software, made sure you installed the latest drivers and checked.your firmware for updates for your audio interface?
sietseschulting wroteI have Studio One 6 now and it's updated. The latest drivers get installed when you install universal control. It prompts you to select your drivers. You say you downloaded universal control but have you actually run it after installation, and checked the firmware for your gear? A good old fashioned reboot is a good idea afterwards too.
Launch a ticket with Presonus support I guess then..Cheers.
i've been away for a long time.
what's so great about version 6? i've spent a lot of money on versions 2 thru 5, and seems kind of pricey. can i get a discount somewhere? : ) |
lisarowe wrotei've spent a lot of money on versions 2 thru 5 So have we all - well 3-6 here but only because I was spending money elsewhere for a while. Start here for 6, https://www.pro-tools-expert.com/production-expert-1/studio-one-6-everything-you-need-to-know Current version is 6.1.1 Great release, personally. I like it a lot. Love the video track and the lyric improvements. Lots of workflow improvements and enhancements. Track templates still needs some work, here at least. $104.95 upgrade at JRRShop https://www.jrrshop.com/presonus-studio-one-professional-upgrade |
Didn't notice that. But I bought my own upgrade from 5 to 6 at Best Service - they had ranges if serial numbers as released from Presonus. As I recall I had to wait a day or something for some new serial numbers to be released
FWIW I would try the "notify me" thing. Maybe at that price Presonus are more restrictive of no. of sn's they release. FWIW Best Service lists the upgrade at $127.
I complained about payment issues on the 6.1.0 thread. It appears the issue still persists, Presonus, are you fixing this?
viewtopic.php?f=151&t=49466
Has anyone else noticed periodic, erratic, high CPU usage since updating to Studio 6.1.1?
I started having these problems two weeks after updating, and now it’s happening so often I can’t use the program. When I pull up the performance monitor, all the VSTs show high CPU usage when there should be minimal. I have NAP enabled, and this happens even with a new file and 2-3 tracks with Helix Native, and some other plugins. |
richardwhite14 wroteHas anyone else noticed periodic, erratic, high CPU usage since updating to Studio 6.1.1? As always,.please put your specs in your signature. Windows 11 by any chance? If windows I suggest you download and use latencymon.
richardwhite14 wroteHas anyone else noticed periodic, erratic, high CPU usage since updating to Studio 6.1.1? As Al said, put your specs in your sig, but I've been Windows 11 and a new computer (specs in my sig) for a few months now with 6.1.1 and have had no issues...In fact, I can now open a session with 80 tracks on it and run it with no hiccups at all. My previous PC almost choked to death on it. I had to give it the Heimlich every time I tried. I WAS having trouble with 6.1 at first, but it ended up being a Kontakt 7 issue, NOT a Presonus issue. Native Instruments have since patched Kontakt 7 and I have had no issues since.
There is one big windows 11 slowdown issue right now it's a particular update that needs removing to resolve it (if you don't have the issue then it's obv not an issue) which is why I ask. He can Google how to resolve that.
Otherwise it's latencymon.(and we need his specs). To be honest this should be troubleshooted on a separate thread..Maybe the mods can move these posts to a new thread.
Hi, Studio One Pro 6.1.1 shows an error on my system in the following scenario:
1. Add Impact XT Instrument Track 2. Create Instrument Part 3. Convert Instrument Part to Pattern 4. Transform Instrument Track to Audio Track 5. Transform Audio Track to Instrument Track Studio One displays an error and the track is not properly restored. Replacing Impact XT with Groove Agent and repeating those steps crashes Studio One. Support ticked created. UPDATE: "We can confirm what you've reported and have passed it along to QA. "
Studio One 6 Pro; OS: Win.10 Pro
Computer: Dell Precision M4700 Mobile Workstation, i7-3740QM 16 GB RAM, 256GB System SSD; 2TB Library SSD; 1TB Projects SSD, 4TB Backup HDD Audio Interface: M-Audio ProFire 2626; M-Audio Air 192-6 MIDI Controllers: Roland A49, Korg MicroKontrol, Korg PadKontrol, Peavey Studiomix, NI Kore 2 |
Users browsing this forum: No registered users and 37 guests
