Hi All,
I currently use Impact XT for drum replacement. The way I do this is to copy the drum track's bend markers to a MIDI track which gives me the drum hit velocities on a single note. What I then do is select the MIDI notes using a velocity range and then transpose them so I end up with something like: C2 1-29 C#2 20-59 etc. The drum library I'm using (from Nashville Sample Company) is multi-velocity (5 ranges) with round robins for each range. I've set this up so that each velocity range is on a single pad with round robins enabled. This way I'm getting the velocities to match the performance and get to use the round robins. I was wondering whether it's possible to create a macro that does the MIDI range selection and transposition, or even better, if one already exists? Cheers, Chris |
Quick update:
I tried creating a macro to do what I described above however it didn't work. I used the SelectNotes (with a range) and then Transpose five times, each time for a different range. Do I need to add some sort of "pause" between each transpose? |
Users browsing this forum: No registered users and 64 guests
