Hi all: I just purchased an update from S1-5 Pro to S1-6 Pro through Bestservice.com and was provided with a serial number for version 6. The instructions say to...
1) Log in to the Presonus website and select "Products"
2) Select the version I already own (S1-5 Pro)
3) Click on Upgrade
4) Enter the S1-6 Pro serial number
When I enter the new serial number in the little window nothing seems to happen, and the window just kind or jumps and resets showing the number that I entered.
So I downloaded S1-6 Pro and it comes up in DEMO mode. I can't get it to activate to Pro mode. Am I doing something incorrectly?
I need to resolve this ASAP since I will be teaching a course on Studio One starting in a couple of days and my students will likely be lost without my help
Thanks
Dell Latitude E6530, 16 GB Ram, Two 1-TB SSD
Windows 10/64
Novation LaunchKey 49 USB Keyboard
Studio One 6.5.2.97444 Win x64
by Vocalpoint on Wed Mar 29, 2023 11:38 am
alfredohuerta wroteThe instructions say to...
3) Click on Upgrade
Arthur
I upgraded to 6 back in Sept 2022 but went through the same steps and it worked fine.
Firstly - in your instructions above - are you logging on the "Presonus" website OR your MyPresonus area? Assuming the latter but want to make sure.
Secondly - if your serial entry is not working - there may be (super rare but possible) something wrong with that serial. OR - your browser. What browser are you using?
Finally - until you actually sort these first two steps out and get that serial properly bonded to your MyPresonus account - no amount of downloading will take the installer to Pro from Demo.
And you should be getting prompted to login to your Presonus acct - when running v6 setup - like so:
Update when you can.
Cheers
VP
by jazzundso on Wed Mar 29, 2023 11:47 am
Considering the time pressure, did you contact tech support as well?
If this is a wrong behavior (I can't tell because I never went through this process), then probably only PreSonus support can help.
Lukas Ruschitzka
Studio One Specialist
Studio One Tutorials || Studio One Scripts & Add-ons || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ]
Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate
by alfredohuerta on Wed Mar 29, 2023 3:02 pm
I did have to log in on that page shown with my email and password and it didn't work. I also did contact Presonus support but no response yet.
I'll keep trying.
Thanks.
Windows 10/64
by Vocalpoint on Wed Mar 29, 2023 3:08 pm
alfredohuerta wroteI did have to log in on that page shown with my email and password and it didn't work. I also did contact Presonus support but no response yet.
Hmm...if you cannot login through that dialog pictured above - that would logically tell me you either do not have a MyPresonus acct or the credentials are typing in are incorrect.
To ensure your credential are working - you first need to get into your MyPresonus acct first (on the web) to get anything going. If you can login here:
https://my.presonus.com/products/all
You should see all your previously purchased stuff - AND add that new v6 serial.
Then use those same credentials to login to your MyPresonus acct during setup.
VP
by alfredohuerta on Wed Mar 29, 2023 7:28 pm
Actually, I can login but even though I am logged in when I paste the serial number that I received from BestService.com it doesn't seem to work. I'm still waiting for a response from Presonus Support.
Windows 10/64
by SwitchBack on Thu Mar 30, 2023 3:02 am
So you went to your My.PreSonus account, proceeded to Products/Recording Software, found your older version of S1 with the green 'Upgrade' button and went through the motions of entering the product code you purchased, right?
Then when you now log in on your My.PreSonus account and proceed to Products/Recording Software you should see Studio One Pro V6 listed. If not then the registration didn't take.
by alfredohuerta on Thu Mar 30, 2023 7:58 am
Hi SwitchBack: Exactly as you say. I will wait for an answer from Presonus support.
Windows 10/64
by alfredohuerta on Fri Mar 31, 2023 4:34 pm
OK, so I contacted Presonus support and they told me that the serial number that BestService gave me for the update from S1-5 Pro to S2-6 Pro was not correct. That incorrect serial number is for someone moving from the Artist version to the Pro version. I have now contacted BestService support and am waiting for an answer from them with the correct serial number.
Windows 10/64
by alfredohuerta on Sat Apr 01, 2023 5:58 am
Finally solved: I contacted BestService about the information that Presonus said about the incorrect serial number. BestService said that Presonus sent them a bunch of incorrect serial numbers so it looks like I wasn't the only one with the problem. I now have a correct serial number and everything is OK now.
Thanks for all your comments and support.
Windows 10/64
Users browsing this forum: No registered users and 72 guests
