Hey guys,
I`m using Studio One 6.1 with a StudioLive 32S console on Mac Mini M1. Whenever I was working with the console I did not care that inputs where named like "Input 1, Input 2 .... Input 64" because it was quiet acurate. Today I`m hooking up my e-drum set Roland TD-50X to Studio One which offers 32 Ins and Outs. I installed all drivers from Roland and all inputs are recognized by Studio One - but they are not named. Is there a way to "read" it from the device or drive because I saw it YouTube with Version 3.X that this should work - by the way it works on Windows as well Thank you for your help! Alex |
In the I/O Mapping of Studio One you can set the name of each of your Roland inputs.
See the attached picture. After the input is mapped, you can double click where the red arrow is pointing to rename. The new name will then be available as your input name, not "Input 2" or whatever. You can do the same for all inputs and outputs which definitely saves some friction. |
The way the ports appear across the top is from the OS.
You would have to map out your inputs, play #1 and see what lights up then name the device properly. Rinse and repeat. Do it once and export it then it can be imported into songs and templates.
Nothing you can do in S1 to change the top, that comes from the OS probably.
You can change what you see as inputs to your tracks, you create and name the inputs but I haven't seen anything done to the top.
A saw it on youtube with an older version of studio one - maybe it’s fake what the author said:
https://youtu.be/xg2EqThy8Ow (Relevant information starts at 03:56mins) |
Users browsing this forum: No registered users and 24 guests
