Since I started using version 6 I have had this weird issue where if I leave a session open for a few hours and come back to it (about 3 times out of 10) when I hit play it will freeze up. The play button will turn green but the playhead will not move. The session will save but I will get a pinwheel if I try to do anything else. This happens with no plugins as well. I was on windows when V6 came out which is when it started doing it. I'm now on a mac studio and I am having the same issue. So it's obviously a DAW issue. It does it in native AND Rosetta as well.
Is anyone else getting this?? Mac studio 10 core running ventura RME Madiface pro Ferrofish A32 pro running 32 channels of analog hardware |
Check your power saving settings. I'm not a Mac expert, but in windows I disable any power saving for USB devices in device manager, and I turn off the sleep mode/hybernation features.
It's also possible drivers are misbehaving with power management, but it's hardly an issue if it's all off. Finally check to see if there are any processes in the mac taking up a lot of CPU or memory. You could also check the CPU of your plugins in studio one (I appreciate you already said you tested it without plugins). Oh and BTW playhead not moving can often be an issue with the audio interface driver. Make sure your interface is on the latest driver and firmware.
I do have all the power-saving options off. RME drivers are known for being stable but you never know. Thanks for your reply and help
quote="PreAl"]Check your power saving settings. I'm not a Mac expert, but in windows I disable any power saving for USB devices in device manager, and I turn off the sleep mode/hybernation features. It's also possible drivers are misbehaving with power management, but it's hardly an issue if it's all off. Finally check to see if there are any processes in the mac taking up a lot of CPU or memory. You could also check the CPU of your plugins in studio one (I appreciate you already said you tested it without plugins). Oh and BTW playhead not moving can often be an issue with the audio interface driver. Make sure your interface is on the latest driver and firmware.[/quote] |
Are you running the kernel (v3) drivers or Driverkit (v4) drivers for your RME?
Lots of discussion over at RME's forums over both. I am new in the RME ecosystem but the v4 drivers (with accompanying firmware) for 802 have been good on my Mac Studio so far. Also Ventura 13.3 appears to have fixed some long standing audio issues. |
Users browsing this forum: No registered users and 34 guests
