Hi I have a new computer with windows 11
I encounter crackling noises
in my projects.
Although the cpu is on minimum
My interface is ssl big six
I tried downloading the latest drivers but I still hear this crackling
You hear them every time not frequently but they pop up every time.
I would love to know if anyone has an edge and how to handle it
Thanks .
by SwitchBack on Thu Mar 16, 2023 6:10 am
You may be clipping your inputs and/or outputs. See if it also happens when you use more conservative levels for recording and playback.
by andreasmller1 on Fri Mar 17, 2023 3:23 am
I have a similar problem to the one that h-sstudiostudio has. My audio interface is a Presonus Studio 6/8 and it worked well with my PC being on Windows 10. I got a new faster PC (CPU is an I7-12700K) and Windows 11. I can eliminate the problem by switching the driver to the Windows audio driver but that´s not a suitable solution.
@h-sstudiostudio: What buffer size are you working at? What is your CPU, GPU and RAM size? Maybe we have some similarities in the configuration which leads to that problem.
Windows 11 (64 Bit), Studio One Professional 5.5.2 (64 Bit), i7-12700K, 64GB RAM, Geforce RTX 3080
by SwitchBack on Fri Mar 17, 2023 5:08 am
With a new computer it's important to check the audio settings, the sample rate in particular, of system audio and all other apps using the audio interface. When in serving all users the interface has to switch between settings then that will cause hiccups. Just a thought.
by andreasmller1 on Fri Mar 17, 2023 5:26 am
SwitchBack wroteWith a new computer it's important to check the audio settings, the sample rate in particular, of system audio and all other apps using the audio interface. When in serving all users the interface has to switch between settings then that will cause hiccups. Just a thought.
The audio setting are the same in Windows and Studio One. The same crackling problem also occurs in other DAWs. On the last PC I worked with a buffer size of 1024 because it was quite stable with high CPU load. Now this setting is unusable beacuse of crackling. Maybe it has something to do that the audio interface has no special Windows 11 drivers.
by AAV on Fri Mar 17, 2023 7:21 am
Studio One 6.6 Pro, Audient ID4 mark II,
Gigabyte Designair Z390, 32GB DDR4 3200, Intel i9-9900K 4.8 GHZ, 2 TB & 1 TB SSD, 3 x 1TB 7200 rpm HDD, Windows 11 Pro 64 23H2
by andreasmller1 on Fri Mar 17, 2023 8:16 am
Thanks a lot @AAV for that link.The results with Latencymon are crazy. On my old PC (i-8700) it was 83 and the new PC has 15392!
There was a hint in the linked page to use MSI mode utility v3 and I followed the instructions in the following video: https://www.youtube.com/watch?v=43gskMlby_4
After the small change in the GPU setting my result in Latencymon is now 35.
If a plugin like Diva from u-he uses multiple cores the crackling is still there. But that could really be specific to such a plugin.
by AAV on Fri Mar 17, 2023 2:27 pm
andreasmller1 wroteThanks a lot @AAV for that link.The results with Latencymon are crazy. On my old PC (i-8700) it was 83 and the new PC has 15392!
Interesting but not exactly what I expected. How does Diva fare on the old PC? What graphic card and OS?
by andreasmller1 on Sat Mar 18, 2023 2:34 am
The old PC runs on Windows 10 and I had no problems with Diva no matter which buffer size. The multicore mode decreased the CPU load quite a bit and I always had it switched on. I don´t know why Diva behaves different now. The graphic card was a Radeon RX 580.
What did you expect to happen and are there other things I could tweak?
by AAV on Sat Mar 18, 2023 5:03 am
andreasmller1 wroteThe old PC runs on Windows 10 and I had no problems with Diva no matter which buffer size. The multicore mode decreased the CPU load quite a bit and I always had it switched on. I don´t know why Diva behaves different now. The graphic card was a Radeon RX 580.
I expected the issue to be related to your CPU's P and E cores and not so much on the GPU. But it's all interrupts related. The only thing I could suggest would be (if you haven't already tried) to set your MSI mode priority to high if you have it defaulted to normal. You can always go back if it doesn't help or makes things worse.
You might check for audible crackles and check latencymon while playing Diva with and without it's gui open. The fact it's not just Studio One points to Win 11's (current) limitations in scheduling the interrupts adequately for realtime audio. I don't think Windows 10 would be any better as the "problem" is tied to the newer (12 and 13 gen) CPUs with Performance and Efficiency cores, making interrupts scheduling for realtime audio and video more complicated. MSI has been around for a long long time but hasn't generally been needed (maybe for high end gaming). Sorry I can't help more. My own system is a self built 9th gen I9 with conventional architecture. Good luck and hope this helps.
by andreasmller1 on Sat Mar 18, 2023 5:21 am
Thanks for your detailed answer. I already have the MSI mode priority set to high. The default priority was "undefined". The Diva gui seem to have no impact on the crackling, it happens whether it´s open or closed. Maybe I ask the u-he tech support.
It´s weird that there are such basic problems with modern OS and CPUs.
The game I´m currently playing also runs smoother now so the MSI tool helped also in that area. I´m very thankful that you helped me by posting the link to the tech forum.
by AAV on Sat Mar 18, 2023 10:30 am
Very welcome. Happy it helped you. Best of luck.
Users browsing this forum: No registered users and 58 guests
