Beginner here. See attached screen shot. After much editing, most events on my tracks have turned black, while some events remain the assigned track color. Not sure what I have done!
Can someone explain?
Much appreciated. Pat
by Lokeyfly on Mon Feb 06, 2023 3:20 am
Hi patriciadaley and welcome to the forum!
You didn't complete the editing on the events (sections). So for example, you edited an event by detecting transients. You edited some parts but moved on to other events to edit those. You never finalized the event. To finalize an edit such as an audio event, right click on it and select to bounce the selection. Then the track or event color will return.
S1-6.0.1, HP Omen 17" i7 10th Gen Laptop, 32 GB ram,512 GB TLC M.2 (SSD) and 1 TB SSD. Win10 Pro, Audient iD14 MkII, Controllers: Roland JV-90, Arturia Keylab 49 MkII, Atom SQ, Faderport 8, Roland GR-50, Roland Octapad. MIDI Patchbay: MOTU MIDI Express XT, Monitors: Mackie HR824, Yamaha HS-7, NS-1000M, Mixer: Yamaha Promix 01, Rane HC-6 Headphone Mixer.
Latest albums on iTunes
"Amber & Blue", and "Reasonable Approach" available on all major distribution music services.
All songs copyright.
by jazzundso on Mon Feb 06, 2023 7:43 am
Welcome to the forum!
Lokeyfly is right, you're in "Show Bend Markers" mode, that's why the audio events are black. However, Bounce is not the solution (there's no need to bounce and create redundant new audio files, and with bouncing you will loose the original event).
You can just right-click the event and uncheck "Bend Markers". This will return to the "normal" mode with your regular colors...
Lukas Ruschitzka
Studio One Specialist
Advanced Studio One Tutorials || Free Studio One Scripts || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ]
Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate
by patriciadaley on Mon Feb 06, 2023 4:09 pm
Thanks! It's the first time I've used the bend tool. I don't think I could have figured that out. Much appreciated!
by Lokeyfly on Mon Feb 06, 2023 8:20 pm
jazzundso wroteWelcome to the forum!
Ah, I didn't realize or I just forgot to uncheck bend marker, probably thinking the event didn't hold.
Thx.
As to bouncing though, one won't lose the original event ever, really. The event is a clip still in the audio pool. I'm never worried about too many clips as it's so easy to eventually remove all unused audio clips. That's a rather defining moment to be aware of, but I Save As to a new song, so there's never any old clip issue.
Thank you for the uncheck reminder though! :+1
by jazzundso on Tue Feb 07, 2023 2:09 am
Lokeyfly wroteAs to bouncing though, one won't lose the original event ever, really. The event is a clip still in the audio pool.
The event is not the clip. Sure, you won't lose the clip (audio file). But in case you have applied any editing to the event (such as fades, volume change, EventFX) this will be baked in when bouncing so you lose these edits as parameter changes and can't modify these changes anymore (unless you start from scratch). That's what I meant when I said you lose the original event.
Lukas Ruschitzka
by Lokeyfly on Tue Feb 07, 2023 5:53 am
I never said the event is the clip. I said the event is a clip. Meaning coming from or changing to more clips. The point is a history of finalized edits is accessible.
Audio events at some point don't sit there with edits not printed (baked as you say). Sure, they can if that was someone's intent is not to do anything with the final result, such as stem, or solidify the resultant edit. Perhaps you work with a dozen or so partially edited audio events. I think its fair to say many if not more, dont, particularly with audio. With audio, many often tend to poop or get off the pot. (If I'm paraphrasing). ;)
I think your point is in-process edits, and that's probably fair to say. Though editing audio typically requires not having them sit and lay around half edited. They inevitably do get printed (bounced).
To extend an olive branch. Sure, I probably should have said an event is from a clip. My bad.
by Tacman7 on Tue Feb 07, 2023 8:24 am
Yea my definition of destructive editing is from the cubase days where you processed a fade in off line and you changed the original file.
When comping and you have a track with many pieces you need to bounce that to take it to melodyne but you could save a copy of all your edits if you think the editing has to be revisited. So Save a copy and bounce a copy.
That's the only destructive part of bouncing is loosing your edits. I quit doing that because I never revisited any editing.
Bouncing consolidates and replaces long files with relevant content. After bouncing to go into melodyne I bounce to get rid of the melodyne edits. I see an overhead with leaving them in the song as far as boot up time. I use it to print fx and use different patches from an instrument on one track.
I do not think of bouncing as destructive myself.
Kitchen Computer - Microkey Air Eris 3.5
Win10 Ryzen 5 3600 - Radeon RX 590 - 512GB SSD interface: Motu M2
Kitchen Audio Mac Mini M1 Apollo Solo
by Lokeyfly on Tue Feb 07, 2023 11:16 am
Tacman7 wrote: "When comping and you have a track with many pieces you need to bounce that to take it to melodyne but you could save a copy of all your edits if you think the editing has to be revisited. So Save a copy and bounce a copy."
Excellent alternative and something I do. I almost always save a copy of a comp, by dragging it to the back of the song. Then bounce the existing also edited comp in place. This serves two useful purposes. One, it preserves the edits of the original as you say. Two, it shows where you originally comped, so if you use that for example another verse. Drag it to the other verse, and you see what has already been used (lanes or parts promoted). Very useful.
My wording should have been better, but that's not to suggest you can't return older clips. You can. To Jazzundso's point is if the event is undergoing edits, and you wanted to keep that progress going, you can right click and "uncheck bendmarkers" to get back the color of in this case, a transient detect.
Tacman7 wrote: "Bouncing consolidates and replaces long files with relevant content."
Couldn't say it any better, myself.
Users browsing this forum: No registered users and 29 guests
