Trying to assign parameters (filters etc) to my Oxygen 49 knobs from my Cherry Audio Elka X VST plug in on a Studio One track. Nothing happens.
scottnorman2 wroteTrying to assign parameters (filters etc) to my Oxygen 49 knobs from my Cherry Audio Elka X VST plug in on a Studio One track. Nothing happens. I'm not sure what you've done/tried so this might be some stuff you already know. Also, specs are a good thing. Most of us put them in the sig. In the upper left, there are two important controls: The furthest left is the parameter you want to control, right next to that one is the controller you are using. Sometimes you have the manually "link" them with the little arrow/triangle in between. It is possible that you need to set up the controller as under options/preferences. Just hit "add" and then "new controller" to set that up (assuming you don't have your controller/s listed) |
Users browsing this forum: JohHuisman, Lokeyfly, Vocalpoint and 92 guests
