Auto Punch Issue
Posted: Sat Feb 04, 2023 2:12 pm
by bendswede
I'm not having any luck getting Auto Punch to work, or pre-roll for that matter. Using latest version of Studio One, in a Mac. Looked at videos, set the loop, ets (not enabled). It's not starting to record when I reach the loop/section I want to record/punch into. Wassup?
Re: Auto Punch Issue
Posted: Sat Feb 04, 2023 5:16 pm
by Tacman7
This is what happened when I tried it. Mac on the bottom.
- PunchInMac.gif (175.46 KiB) Viewed 769 times
I thought you might have the locators backwards but you can't do that anymore.
What version are you using? Good to put your specs in your signature, click below in my signature.
Are you hitting the record button to get the process started?
Maybe some pics of your setup would help.
https://s1manual.presonus.com/#Recordin ... 257C_____3
Posted: Sat Feb 04, 2023 6:23 pm
by garyshepherd
Never use Auto Punch - just record on a separate track and comp it to the original track.
Posted: Mon Feb 06, 2023 11:30 am
by DJKeys
S1 appears to be recording, but only recording silence. Check your track input settings. Works fine on my Mac-
-dj
