Bug or Feature: Converting MIDI part to Pattern results in loss of data - XLN Audio XO
Posted: Sat Feb 04, 2023 7:42 am
All
Based upon a thread I was reading on KVRAudio - a user there has been using XLN Audio's XO drum plugin lately in Logic.
Due to XO's fairly restrictive capability (just really able to create 2 bars of content) this user wanted the ability to create more "loop" variants to build out his track.
Since XO allows us to drag-drop the MIDI of its current pattern right into the host - this gives us access to the RAW MIDI but editing that way might be a chore.
So he decided to go with Logics "Convert MIDI Region to Pattern" function to use Logic's pattern editor to modify the core pattern throughout the song. However, once complete he noticed MIDI that came over in the initial export was now missing from the converted pattern.
I figured I would try the same in Studio One and the end result was similar - but not exactly as bad. I picked the same XO pattern that he was using - exported out the XO MIDI, duplicated it to a new track, converted that MIDI part to a pattern and immediately noticed entire key tones were missing in the conversion.
Also in Logic - when you do a "select-all" on a MIDI part - the app gives the user a quick total of all the selected notes - which he used to compare the amount of notes between the original midi part and the converted pattern. He noted that Logic dropped somewhere like 20% - which is very significant. If there is a way to see how many MIDI notes are selected in S1 - that would be good to know.
If anyone else has experienced this "note" loss when converted MIDI to pattern - please chime in. Maybe this is by design - it would be good to know when using this function.
Cheers
VP
Cheers
VP
