SOLVED - Elektron Analog Rytm mk2, Overbridge and Studio One on macOS
Posted: Sat Jan 28, 2023 12:00 pm
I’m having a hard time to get any audio from my Analog Rytm mk2 (and my Analog Four mk2 too) using Overbridge in Studio One version 5.5.2.
I’ve tried both the AU and the VST3 plugins without any luck. Controlling the units work – if I turn a knob on the hardware, the corresponding knob in the GUI will turn and vice versa.
Both units are set to “Overbridge” in the USB Settings.
RTFM, you might say.
Well... It works in Ableton Live 11, it works in Reason 12 and it works in Logic Pro.
But, I want to use Studio One. That's my main DAW and the one where I'm most efficient. It's also the best DAW, IMHO
Any thoughts? Ideas? I've asked the same question on the Elektronauts forum, but since Studio One is the only software where it doesn't work this seems more like the right place to ask the question.
I’m running the latest OS on both the Elektron Analog’s and the Overbridge Engine is the latest too (version 2.1.5.4) on macOS 12.6.2.
Cheers
David
Cheers
David
