SOLVED - Playback cursor isn't displayed with OBS studio.
Posted: Wed Jan 25, 2023 6:12 am
by Nothingness
After I took a video of Studio One 6, I found the playback cursor isn't displayed. Capture Cursor is checked, of course.
Has anybody had the same experience and got a solution?
Re: Playback cursor isn't dispayed with OBS studio.
Posted: Wed Jan 25, 2023 8:32 am
by Tacman7
Nothingness wroteAfter I took a video
Could you describe this process? what you were using to capture the video?
Thanks
Posted: Wed Jan 25, 2023 10:32 am
by mikemanthei
That's a classic problem with all screen sharing apps like OBS and zoom and a few others I've tried. If it's the same as what I discovered you are also be missing drop-down menus. The easy workaround is to share the entire screen and not just the particular application.
Posted: Wed Jan 25, 2023 10:45 am
by jazzundso
Is your video driver up to date? Capturing Studio One including the play cursor works just fine here, in OBS Studio or Camtasia.
Posted: Sat Feb 04, 2023 10:44 am
by Nothingness
Tacman7 wroteNothingness wroteAfter I took a video
Thanks
Oops, my bad. I used OBS Studio and Reastream for taking the video. I followed this instruction:
https://youtu.be/tj54m6vl38M
Posted: Sat Feb 04, 2023 10:45 am
by Nothingness
mikemanthei wroteThat's a classic problem with all screen sharing apps like OBS and zoom and a few others I've tried. If it's the same as what I discovered you are also be missing drop-down menus. The easy workaround is to share the entire screen and not just the particular application.
Aha! I should give it a shot! Thx!
Posted: Sat Feb 04, 2023 10:47 am
by Nothingness
jazzundso wroteIs your video driver up to date? Capturing Studio One including the play cursor works just fine here, in OBS Studio or Camtasia.
Yes, it does. I think what mikemanthei is right. Need to act soon.
Posted: Tue Feb 07, 2023 6:09 am
by Nothingness
You are right! It works perfectly now. Thank you!
