Almost everything I do as far as the "wrenches" are concerned are remembered the new time I do a project/new or otherwise. But there is one thing that does not: Under mixer/"input", if you check it it is lost the next time you open Studio One.
This has been there in previous versions as well. I'm puzzled. Sure, a keyswitch, that is fine, but I'm not clear on why almost everything using the wrench is there on new/old projects, and this is not Other than the mentioned keyswitch, is there any thoughts or logic behind why this is the case? |
I'm not following...
This is what the wrench looks like in my mixer: The one Input Controls is the only one that says input on it. That shows the trim controls. I set it and rebooted and it was still set.
Yep, I totally agree with you that this is weird and annoying. I want the gain and polarity controls every time. Although using a template does get around this problem.
Whew! So it's not just me. I'd submit a ticket, but we most likely know how that will go
In the meantime, my keycommand will have to do. And you are of course correct, a template is a good workaround. For me, it's bringing down unruly synth patches and dialing in guitar and bass inputs at times. OH! I forgot to mention, if you just mean the input (which of course requires an extra step again) and not the top of the channels in the mixer, it's right there However, ever single "new" project still has the wrench part unchecked. Ah, it's almost 2023 and after 2 decades of really killer improvements....still with the workarounds.... |
I can see the reason why the Input meters don't show up every time. I think its because the mixer real estate has to get pushed over to expose all the input channels. And if you have a lot of inputs then they all get exposed hiding even more mixer channels.
I think it's by design and not a bug either. The reason to see input channels should be decision you have to make each time in my opinion. It's not something you always need to monitor either as the input meter to the track will often usually suffice.
It's possible you are correct, but it's still kinda weird. Like I said, the "input" channel AWAYS shows it. So, I dunno.
It's TOTALLY a first-world problem, but it's also one of those things that (old school reference) "make you go hmmmmmmm" Remember: It's the check box in the wrench settings that does not stay on that is my biggest weird thing. If it was always on, then I'd say you are correct. |
Users browsing this forum: bartbalint, jazzundso and 78 guests
