Great you're happy with Studio One version 6. Btw, you can post you're music in the made in Studio One Forum section as you probably knew.
I'm pretty sure it wasn't lightening that set your speaker monitor to flames. It was the record level volume. (Joking). It is really loud though, and sounds at about a level of 4 LUFS. That's louder than really loud annoying advertisements. The speakers will have no chance of recovering from such a signal when turned up. Compare your Rhamstein video volume which they are no newcomers to maxing their audio signal. That video is less loud than yours. Anyway enjoy Studio One version 6!
Well, after finishing my last project "Palette" to be released Dec. 9, on Bandcamp and later in the week on Spotify and other distribution affiliates. So finally, I got a chance to upgrade to S1v6. The single biggest feature I like a lot is the Pro EQ3 with its dynamic control over each band. This is especially strong when side chaining and seems even nicer than my Fabfilter EQ. Ive already tried dynamic side chaining with the Pro EQ3, and it's top notch! The pass through monitoring of each band is also a fantastic addition, especially in checking sub bass issues, and practically any other area where monitoring frequencies help the cause.
To me, this is an easy plugin worth $150+ on its own, so any other features in version 6 are icing on the cake. Yes, I expected some additional areas to get Studio One up to speed on some standard sequencing protocol, but I won't go into that here. I'm enjoying the product and results very much. Results being the underlined word. The install right from the Presonus website was instantaneous, shown instantly in my profile and ready to go right after purchasing. No searching elsewhere needed, and as I've read, some went through hoops getting things up and running. I'm sure the initial release time and demand impacted that. Who knows. Thank You Presonus and those who helped in the effort of version 6. Studio One remains non intrusive, and still has a measure if elegance to it.
I got to see Les Paul at the Iridium, just one year prior to his leaving this world. A true innovator and funny guy!
CHORDS AUDITION
Just installed new S1 license and I have big surprise. I cannot audition note chords in the Editor. Is that true or I'm simply missing something ? For example, in Ableton I can simply select2 or more notes and while they are selected they simply make a sound. At this moment, I can only hear one note at the time. I have seen a discussion on this forum dated from 2019 and now its almost 2023. Is this implemented or not ? Otherwise I have to go back to my old DAW |
Thoughts
There goes the bandwidth. @ Surf.Whammy This is the Studio One 6.0.1 official discussion thread. Not sure such non related mega posts should be placed here.
Can you clarify some of your comments below...
I understand that S1 v.6 has enhanced INTEGRATION with Notion 6, and that it has improved the notation features within S1. But are you claiming that Notion is completely packaged inside of S1 now, making Notion an unnecessary program? Is everything that you would previously use Notion for now doable within Studio One? Except exporting/printing options? Is there any thorough feature comparison sheet published somewhere? Or any walk-through of exactly what's been imported into S1, or remaining as Notion-only? Also, does the Network integration feature work just as well as ReWire for continuing to connect the 2 programs? Surf.Whammy wrotearthurklisiewicz1 wroteCHORDS AUDITION |
Duck.......incoming!
Hi, guys, I have one important question: what for is Explorer window opened after mixdown? I know, I can disable showing it by unchecking "Close after", but this is so stupid - I would like to close all windows after mixdown, not choosing between one of them...
Tell me, why PreSonus also in 6th version did not add some option to disable this separately? Or maybe I missed something out? |
I love that it opens the folder where the mixdown is stored. But yeah, it seems like it would be an easy option to implement.
konradlesniak wrote......I know, I can disable showing it by unchecking "Close after", but this is so stupid - I would like to close all windows after mixdown, not choosing between one of them... There you have at least disabling globally by unchecking. How is it that you're getting numerous windows open? Are you mixing down numerous songs at a time? Presonus can't predict every scenario. Like greghart, I like that the rather important export is displayed with an open window. It simply confirms the task completed and for your viewing (or not). Not an additional options select for leaving songs 1, 4, 7 and 8 open.that's just the kind of weight some other DAW's provide that while fixing one need, add a slew of more and more housekeeping features in the way of dedicated mixdown needs. Mmv respectively. I don't see a simple workaround except checking off leaving the intended mixdiwn window open or closed. How are you mixing to numerous songs to different windows in the first place? If you simply have numerous windows open and layered about, that's likely cause for shame one you when performing a rather important mixdown. One can't put that on development to clean up. Perhaps I'm missing something, which could be possible.
Users browsing this forum: No registered users and 66 guests
