If anyone here has a 12th or 13th gen Intel, I would highly recommend that you make sure that "CPU Parking" is disabled. That was wrecking havoc on my build. I was getting drop outs and audio glitches even when I wasn't doing cpu intensive tasks. Here is a video that describes how to do it.
https://youtu.be/sFz8HRk4WfI |
kevinkbell wroteIf anyone here has a 12th or 13th gen Intel, I would highly recommend that you make sure that "CPU Parking" is disabled. That was wrecking havoc on my build. I was getting drop outs and audio glitches even when I wasn't doing cpu intensive tasks. Here is a video that describes how to do it. Thank you soooo much!!! It won't solve the "dropout bouncing issue" but it will solve my issues with "empty projects" causing cpu spikes on my Intel 12700K. |
Having same issue. Terrible performance overall, but mixdown with realtime causes immediate dropout.
Tried a blank song with just a few chords in Maitai and no problem at all, but loading a song with just three plugins ( MV meter, Fabfilter and SSL Vocalstrip2) and immediate crash of audio engine even when turning plugins off. Totally unusable. Windows 10 and CPU at 5% |
@ darrenbrannan,
A few checks you could run. *. Run mixdown not in real time. * Are tracks, all audio? All Instrument?, Both? *Straight away dropout usually signals either the audio Interface, some exceedingly CPU demanding plugin, or instrument handing many synth voices, or too many instrumemt notes played at one time. In such cases, it's best to render instrument tracks to Audio, then mixdown. *does mixdiwn without plugins still cause dropout? If so, it's likely your audio interface connection, driver, buffer....... Yes, from your explanation, this shouldn't be happening, so youll have to isolate why that is. Another snag is often the computer itself, as in efficient free space on your hard drive, RAM allocation, system requirements. Just saying. , Please provide your system specs in your signature. Thx.
Please try 6.1.1 with latest audio interface firmware and drivers. Also check out latencymon. Further advice is already in this thread.
I've tried this with 6.1 and 6.1.1 with everything updated and I'm still getting the Audio dropout message.
Only happens when I have Pipeline on my master. If I take it off it goes away... Nothing in my setup had changed from 5>6 and suddenly its happening on every mix down!!! |
Im having the same issue with v6 on mac studio 10core in Rosetta and Native. Im getting it on "transform instrument to audio too". Here it is April and they STILL have not fixed this. I use a ton of hardware too. DSo Im surer its pipeline
frank.crow wroteadoniramlipton wroteDid anyone resolve this? |
Its for sure Pipeline on the masterbus. Which makes S1 useless to me. I hsave been having this issue on windows and max. But it doesnt seem to affect the sound? I cant tell. Wish they would fix this. Its been 5 months this has been happeing
Trucky wrotemarkusvogl wroteHi, |
I don't think that Pipeline is the culprit. Pipeline just forces Realtime Render which then activates Nap/Sleep states of plugins. And some Plugins trigger CPU spikes in latest S1, whenever they go in or out of a nap state (some Plugins' own internal nap feature also cause S1 to spike). Best candidate to try is Blackbox HG-2 MS, but S1 has this issue with other plugins as well.
OS: Win10 x64 || Software: Studio One Pro [latest version]
Hardware: AMD Ryzen 9 3950X || Asus Prime X570-PRO || 64GB DDR4 RAM || Asus Dual-RTX2070S-A8G-EVO || UAD2 Octo & Duo PCIe Peripherals: RME Fireface UFX II (+2x ADA8200) || Faderport Legacy || Atom || NI Komplete Kontrol A25 Audio Settings: 44,1/48kHz, 256 Samples, DP Off, 64 Bit |
I have the HG-2 on my drum bus but the dropout only stops when I disable pipeline on my masterbus. I wonder if turning off nap would work. I really hope they fix it. On a side note I dont ever hear the dropouts. Do you? I was starting to think it was just a GUI issue. Like its showing the notification but its not really dropping out.
stefanrauch1 wrote |
I just figured out a workaround. I just made another bus, put all my master bus hardware on that and sent that to the main 2 bus. Even with pipeline on I get no dropouts. But as soon as I enable that same instance of pipeline on the main bus I get dropouts
Same issue here.
I just figured out a workaround. I just made another bus, put all my master bus hardware on that and sent that to the main 2 bus. Even with pipeline on I get no dropouts. But as soon as I enable that same instance of pipeline on the main bus I get dropouts Robdp wroteI've tried this with 6.1 and 6.1.1 with everything updated and I'm still getting the Audio dropout message. |
Its pipeline on the masterbus..
I get the same issue.. I just figured out a workaround. I just made another bus, put all my master bus hardware on that and sent that to the main 2 bus. Even with pipeline on I get no dropouts. But as soon as I enable that same instance of pipeline on the main bus I get dropouts darrenbrannan wroteHaving same issue. Terrible performance overall, but mixdown with realtime causes immediate dropout. |
when you leave pipeline on the master, but remove all plugins from the session, do you still get dropouts?
I always render midi to audio as soon as im sure its all written correctly,, But the problem is it happens when I render to audio too..
I have a brand new mac studio 10core.. It should be good enough. The odd thing is when I get the dropout notification i can never hear it when I play anything back. This leads me to believe the notification itself is the issue. As in it's popping up when there actually isn't an issue.. My mixdowns sound fine. No pops or clicks Lokeyfly wrote@ darrenbrannan, |
I get the same message in win10 here sometimes. Not always but inevitably occurs when I have some automation on one or more tracks near the start of a project. I don't use pipeline as everything except mics are in the box. I've bounced midi to audio, inserted empty space up front, all with mostly little or no success. Like you, I get the message but don't hear a problem with mixdowns. So I just ignore the message.
Maybe it has more to do with how Presonus manages (or doesn't) cores and core balancing. Shows up with pipeline for a lot of users simply because of the cpu load, just like it seems to relate to automation here. Dunno. Just my 2¢ But I agree your mixdowns are probably fine. |
johnboyd4 wroteI always render midi to audio as soon as im sure its all written correctly,, But the problem is it happens when I render to audio too.. After the message, do you guys play back and never get a peak overload amount? Such as 0.3 dB over? Or similar? Point being, you may not. Typically, the message will show how much the overload peaked displaying an amount. Is that happening? I was in numerous discussions years ago in this forum about how Studio One should have a peak Indicator along the timeline, to display where the peak/clipping occurred. Such conversations never meet with any Presonus feedback. Too bad, really. AAV wrote: "....Maybe it has more to do with how Presonus manages (or doesn't) cores and core balancing. Shows up with pipeline for a lot of users simply because of the cpu load, just like it seems to relate to automation here. Dunno." I'm not going down that rabbit hole. Lol What I can suggest is, sure on occasion, a render with my own tracks occur. When that happens and its rare, I usually reduce the gain by a few tenths of a dB. If it still occurs, it may take reducing a whole 1 to 1 5 dBs. That can easily be brought back up later. What the offending issue can then be is either some ultra low frequencies, or transients are causing the overload. So filtering with a HPF at 50 Hz or instrument depending, will almost invariably fix things. P.s. I dropped the effects and master channel part of my response as johnboyd4 mentioned rendering as he goes along. He clearly knows how that is done and the impact that has, elsewhere.
I'm not sure where the OP [kevinkbell] went, as there's no response from him. It's not out of the question there is some glitch with dropouts. It's best to simply undertstand issues case by case.
Filtering low frequencies with an HPF and transient peak checks can and should help. It's helped me in the past with such notices. If all attempts have been made that way, then there could be some deeper issue. It then amounts to other reports, or if issues are isolated to one's machine. That's not saying your system isn't capable. Hardly. It's potentially more something simply unique on one's end. Lots of reports to the very same issue usually spell an issue with the program (bug). I mention HPF specifically because just dropping lower frequencies doesn't always prevent low or sub harmonic issues from occuring, or causing clipping. A good high pass filter with a steep cutoff slope, helps a lot. Just saying. Also heavily stacked notes, dense, or overplayed synth voices can cause clipping at times. Just adding this to the potential fodder. Always under these conditions use a good graphic analyzer that sees very fine spikes, or very low frequencies. Gregor and a few synth (drone and ambient) creators have videos touching on checking some of these newer synth patches with a good analyzer to see such transients, and notch them out. It can and does cause sneaky level issues to be aware of. Just another potential factor to watch for.
Lokeyfly wroteWhat I can suggest is, sure on occasion, a render with my own tracks occur. When that happens and its rare, I usually reduce the gain by a few tenths of a dB. If it still occurs, it may take reducing a whole 1 to 1 5 dBs. That can easily be brought back up later. What the offending issue can then be is either some ultra low frequencies, or transients are causing the overload. So filtering with a HPF at 50 Hz or instrument depending, will almost invariably fix things. I don't know what others in this thread are doing as I was responding to John Boyd's post about dropouts during rendering. My situation is different in that there is no pipeline involved in my case, but seems related to whether I have automation early in the project. I have seems the "a dropout has occurred...." message, and am confident that no clipping has occurred. Projects are properly gain staged, and mixed and rendered to -14 lufs, or -18 lufs at the master bus, depending on end use intention. What I was describing isn't a clipping issue. |
I see. Ok, thanks for that. I'll revisit those points, but glad you made that clear. In such cases, it may benefit checking a fresh or new song. Things work? Then graduate back to where and how automation is crippling your renders/mixdown. In other words, it's most likely within that song. If not and it's a constant issue, it will likely add up to your devices, or as you suggested, core sharing. Only that's probably the last place you'll want to troubleshoot.
What automation do you see as being the culprit? Begining or end fades? Automation is a very solid level along what your faders are doing, or specific parameters, cc controllers, etc. You must be only seeing this occur when you have automation turned on? Latch, write?
Users browsing this forum: MisterE and 35 guests
