Anyone else seeing strange behavior with some plugins in S1v6 Pro? So far I have seen issues with three plugins:
PSP Audioware Echo: The VST3 version will not show up in the effects list. All other PSP VST3 plug-ins show as do the VST2 versions. Izotope Tonal Balance: Bass frequency detection seems way out of whack. This plug-in now detects way more bass than is actually present in a mix. It was fine in v5. Presonus Ampire: all amp models that come with v6 Pro distort horribly when used with any of the included Mixbus consoles. Using the included pedals makes it sound even worse. (As a point of reference this is not the case with Waves GTR, not that they have ever been great). FWIW, I usually only use amp modeling when scratch composing. I use a real mic’d amp/cab for serious recording. Using Windows 10, 32.4.2AI board via FireWire. Thanks, Greg
There was an update to PSP Echo (v1.5) late September. Not quite apples to apples, it is showing up on my rigs, but running Mac arm.
Since the update of S1 6 Waves Harmony doesn’t work anymore. I can see the plug-in in the plug-in list, but can’t use it anymore. I’ve been working on a a mix that had several instances of the plug-in in use, but after the S1 update I got a message that the plying was missing 😕.
Tried reinstalling the plugin. Still not able to use it. This seems like a S1 problem to me. Any help/suggestions are greatly appreciated! |
Welcome to the Forum!
I had a problem with a plugin after the upgrade but I checked it in version 5 and the problem was there too. I have something going on with a video card and I had to disable openGL to be able to see the plugin. Does it still work in version 5? So you were using it in V5... Check plugin information on the view menu and see if there's any info there about it. Waves is really good with support if need be. Good to put your specs in your signature, click below in my signature.
Thanks Tacman7!
I checked version 5. There it doesnt work either anymore All my other Waves plug-ins work.... I can see the plug-in in the Effects window and the Plug-in Manager. My System doesn't have a video card installed. Video through the CPU. I'll try to contact Waves. Maybe they have a solution. |
Creative Intents Tantrum doesn't work properly for me, for some reason it completely breaks the UI of Studio One where clicking on UI parts doesn't do anything, I can fix this by putting focus on another tab in Windows and then going back into Studio One, but it's annoying, I mailed the dev to see if they could help as it's been like this since an update they did a while back, the previous version worked fine but the current version (no way to download old versions either) inhibits this behaviour in both S1 5 & 6.
I'm also having issues with the Cardinal modular build based off VCV rack, the VST3 versions instantly crash Studio One while the VST2 versions work but I wonder if this due to the I/O options for Cardinal and CV routing and maybe S1 doesn't like it ? Some other plugs the VST3 will show up but not the VST2 or vice versa depending on the plug, not as annoying as they're still useable although I'd prefer a shift to VST3 for all my plugs just so I don't have to install twice as much stuff to play this lottery of what S1 will detect |
Users browsing this forum: Anderton and 55 guests
