While Izotope seems unable to provide a version of RX that run in SO6 through ARA2 (and that's a shame because they did it for Logic!), Acon Digital provides its Acoustica Editor that is fully compliant with ARA2.
But it seems that S06 coders have to authorize the use of Acoustica just like they did for Melodyne and VocAlign... So, as James Brown says : Please, please, please, pleaaaaase! |
I'm just trialing Acon Acoustica 7 and I really like it. I found a workaround in Acoustica's manual:
"Using Acoustica ARA in Studio One Unfortunately, Studio One only shows the convenient "Edit with..." shortcuts in the Audio menu for a set of hard coded ARA plug-ins. To use Acoustica ARA, you will need to locate the plug-in in the effects list: ·Press F7 to show the Effects list, if not already visible. ·Locate Acoustica from the Acon Digital sub-folder. ·Click the Acoustica plug-in in the list. Now, move the mouse cursor over the clip you want to edit, press the Alt key and keep it pressed while you release the mouse button." I hope this helps, at least until there's a proper ARA2 support for Acoustica 7 in Studio One 6. |
Pavol Cerveny wroteI'm just trialing Acon Acoustica 7 and I really like it. I found a workaround in Acoustica's manual: |
Users browsing this forum: No registered users and 107 guests
