I created a drum bus...
However, if I add a reverb or any other effects, I can't hear the effect. I then tried to set up an effect through the send of the drum bus, and the same thing... I can't 'hear the effect'. If I put reverb, for example in the inserts of the 'room mics' for the drums, I hear it perfectly. Why am I mot 'hearing the effect' from the drum bus? Thanks |
A silly question probably but are all the drum tracks definitely routed through the bus and not still routed to the main out?
That was it! Thank you
I assumed that when creating a drum bus that it automatically assign the drums to that bus since I highlighted all of the drums tracks then created the bus from there. Lesson learned. Steve Carter wroteA silly question probably but are all the drum tracks definitely routed through the bus and not still routed to the main out? |
It will connect them when you create the bus if you select the tracks and right click on them and choose add bus for selected tracks.
Users browsing this forum: dougasherman, jazzundso, Lokeyfly and 99 guests
