So I'm still using Studio One 4 and was wondering if it was possible to do the following routing in versions 5/6, but in a more handy way:
I create a bus that I call "Return" and route it as a send into the track where the instrument is, and then I add a second track where the recording goes. Is there a more straightforward option for that in versions 5/6? |
Lot of things happened in 5 to routing, not sure if any changes in 6 but you can send most anything anywhere now, check pic, I can select tracks, instruments, bus's, for input as well as the usual inputs.
Yea those are input sources for an audio track so you could record the audio output of an instrument or a bus, or a track.
In 6 if you turn on a sidechain it will create a send from what you want to use for sidechain. Also 6 supports sidechaining virtual instrument so you can use your vocoder and there is a new vocoder as well.
Users browsing this forum: No registered users and 26 guests
