Is there a key shortcut that will allow me to repeat playback :?:
For example:
Let's say I start playback at bar 55. At bar 65, I want the transport playback to jumpback to bar 55 without stopping and continue playback.
Is there a keyboard shortcut that can do this :?: :?: :?:
MacOS, Monterey 12.5, Logic Pro X (10.7.4) Studio One 5 (5.5.2), Focusrite Clarett 8Pre, Behinger X-Touch, Behringer X-Touch Extender
by Tacman7 on Tue Oct 04, 2022 3:32 pm
Not that I know of.
If I started playback at bar 55 when I hit the 0 key on the numpad that will stop the playback, hit it again and it will return to where I started playback, so that could change as you go along.
If you want to loop around like that you setup the loop locators and turn on loop.
https://s1manual.presonus.com/#Recordin ... Tracks.htm?
Win10 Ryzen 5 3600 - Motu M2
by PreAl on Tue Oct 04, 2022 4:02 pm
Create a macro perhaps.
Hit a shortcut to execute macro which:
Marks an end loop marker.
Stops (goes to last played position).
Marks a start loop marker.
Enables loop.
Plays.
Just a pseudo-guess.
If you get one working please post it here.
Studio One Pro 6.x, Windows 11 Pro 64 bit, also running it on Mac OS Catalina via dual boot (experimental).
Presonus Quantum 2626, Presonus Studio 26c, Focusrite Saffire Pro 40, Faderport Classic (1.45), Atom SQ, Atom Pad, Maschine Studio, Octapad SPD-30, Roland A300, a number of hardware synths.
by jazzundso on Tue Oct 04, 2022 4:43 pm
Just three clicks:
- Hold Cmd and click on the ruler to set the loop start
- Hold Option and click to set the loop end
- Click on Loop (in the transport bar) to enable loop
Or you just draw a loop range, again on the ruler.
You can also assign keyboard shortcuts for "Set Loop Start" and "Set Loop End".
Lukas Ruschitzka
Studio One Specialist
Studio One Tutorials || Studio One Scripts & Add-ons || Studio One Tutorial Database || Studio One Toolbox [ s1toolbox.com ]
Clavia Nord Stage 3 - Moog Sub 37 - YAMAHA MoXF6 - M-Audio Axiom Pro 61 - Kawai ES-920 - Studio One 5 - Notion 6 - Orchestral Tools Junkie XL Horns, ProjectSAM Symphobia, Cinematic Studio Series, Strezov Sampling Afflatus, VSL Synchron Special Edition, KOMPLETE 9 Ultimate
by jazzundso on Tue Oct 04, 2022 5:05 pm
The problem with creating a macro is that you probably want to snap the Loop End to the next bar. Which is only possible with the "Forward Bar" command that moves the playback cursor... and this prevents a seamless playback to the loop start. Also, to return to the last play position you would need to enable "Return to Start on Stop" or fire the "Stop" command twice (which did not work in my test).
Would probably be possible with scripting but not with macros alone as far as I see.
If you don't need to snap, the macro seems to work.
Lukas Ruschitzka
by coolmusicgear on Tue Oct 04, 2022 5:05 pm
Thanks everyone for your input, but all the previous suggestions above a not very user friendly and in fact convoluted work arounds to do something that should be as simple as hitting a function key or one letter or key combo on the computer keyboard or midi controller.
by Lokeyfly on Tue Oct 04, 2022 5:21 pm
Want one key, you have it. Two ways actually.
* Drop a marker at the start Pont. If its your first marker, it will be mumber 4 on your keypad (1 is always loop start and 2 is always loop end). 3 is always the start marker, but that is best left at the song start.
You don't even have to press [stop] anytime you hit #4, the playhead will jump to that location. If you set up several markers, just simply select two numbers higher than that marker number. So selecting where marker #5 is, you hit #7 on your keypad. Done. One key.
*The other method is from jazzundso. Simply draw a loop out to any desired length. Select #1 on the key number pad. It is the same.
Another possibility is select to allow after stop. Selecting 0 will return to the original before it goes back to zero on the timeline. I kinda never use that but it's available.
There's really nothing convoluted about it. IMO
New song "Our Time"
https://youtu.be/BqOZ4-0iY1w?si=_uwmgRBv3N4VwJlq
Visit my You Tube Channel
https://youtube.com/@jamesconraadtucker ... PA5dM01GF7
Latest albums on iTunes
All works registered copyright ©️
by SwitchBack on Tue Oct 04, 2022 5:41 pm
Assigning a key to a macro with Stop - Stop - Start will do it I guess.
First Stop stops playback, second Stop returns the playhead to where playback started, and Start then resumes playback.
by BobF on Tue Oct 04, 2022 6:05 pm
Or ...
Use the Play Start Marker. EZPZ!
Playback will resume from the PSM until you move it along to the next location. I have a Controller button assigned to the Set Play Start Marker command, which sets it to the current position.
Nothing easier until mind control is implemented.
Studio One Pro - latest / Win10Pro x64 (latest) / i7-6700 @3.8Ghz / 32G / UMC1820 / Event PS8
RC w/Galaxy S7+ / KKS61MK2 / Atom SQ
by PreAl on Tue Oct 04, 2022 10:32 pm
coolmusicgear wroteto do something that should be as simple as hitting a function key or one letter or key combo on the computer keyboard or midi controller.
That's what a macro does and they aren't difficult. Good luck. Put in a feature request otherwise.
by Lokeyfly on Tue Oct 04, 2022 11:33 pm
"Not user friendly"
"Convoluted"
Were we just corresponding with Mr. One Page?
I'm leaning towards a big "Yes"! :?
New song "Our Time"
by donaldbaarns on Thu Oct 06, 2022 3:42 pm
You have multiple options, many outlined previously.
A few more options:
Map the KB shortcut for "Play Selected Range" to the key of your choice.
Select what you want to play, then press your shortcut and it will play. When you press it again, it will restart at the beginning.
Use Looping without manually creating the loop
Turn on "Loop follows selection" (right-click Timeline, or use shortcut keys)
Select your set of bars (If Snap to Grid is On, it will get right to the barlines.)
With Looping "On" it will loop over your selection, 10 bars, 2 bars, or whatever
Select next section you want to loop/listen too, press spacebar to start and it will loop over that area.
Use Mouse:
Double-click in the Timeline will start playback at bar 55 (or wherever).
Don't move your mouse after double-click (playback starts) Single click if you want to replay, and the cursor jumps to your single click point when playback is already in progress.
Any of those can be added to a Macro button if you wish...
Play Start Marker would allow you to set start point, and a double-tap on the spacebar would go back to your Start Marker and continue playing.
TOOO Many options, use the one that makes the most sense for you...
Don
S1 v6.x Pro - latest version
PreSonus Studio 26, IO 24, Atom
Eris E5s
iZotope RX10 Advanced
Win 11 Pro-32GB RAM-AMD 3900x
AMD 5700XT
Windows 10 Pro-16 GB RAM
MacOS Ventura (13.4) iMac i5 w 8 GB RAM
FB group: Studio One Users-Audiobooks, VO and Podcaster focused:
https://www.facebook.com/groups/StudioOneNarrationVO/
Studio One and iZotope RX Courses for Narrators/Podcasters/VO:
https://www.VOJumpstart.com/
Studio One and iZotope RX Videos for Narrators/Podcasters/VO:
https://www.youtube.com/user/RedBaarnsAudio
Users browsing this forum: jebbyslonar and 72 guests
