In Studio One 6, I've attempted many times to assign a key shortcut for the transport "Forward".
No matter what key I try to assign it simply does not work! However, I have no problem assigning a key shortcut for "Rewind". Help please!!! Thanks. |
Are you sure that you've assigned the key to the correct command? There's "Navigation -> Forward" and "Transport -> Forward".
Lukas Ruschitzka
jazzundso wroteAre you sure that you've assigned the key to the correct command? There's "Navigation -> Forward" and "Transport -> Forward". Thanks. You solved my problem. I was mistakenly setting the key shortcut under "Navigation" instead of "Transport". When I added it under "Transport"it now works. This does raise a 2nd question, what exactly is "Navigation > Forward" suppose to do??? Because when I did mistakenly setup key shortcuts there, when I tried to use that key shortcut I didn't see anything in Studio One happen. |
Users browsing this forum: johndoe313 and 41 guests
