Hi
This is probably best explained with a 1 minute video. (Please note there is no issue with the stand alone version of Analog Lab V). In summary, a controller looks like it's working visibly but it isn't if I use a dial on my controller. If I use a mouse it's fine. All my dials etc have this issue. Please have a look Thx...
Ah bollocks!
Thanks for the response... BTW I only just bought this plugin myself.
Hmmm this works perfectly fine in Reaktor 6.
As stated standalone version works just fine. I'm starting to think it's a specific issue with the Analog V plugin (5.5.1. 2692 x64) under Windows (at least). It may work in other DAWs but it may need adjusting for compatibility with Studio One. I should log a ticket with Arturia tech support first.
It all works great under V6 now. I will make a video on it. I have to install OBS on this particular Win 10 laptop I am running Studio One 6 on. Also a little busy right now too but I will get onto it. It has changed a little in how it works. A window needs to be open though for real time control from controller encoders will take place. It does work and you can record the movements.
Jemusic wroteA window needs to be open though for real time control from controller encoders will take place. It does work and you can record the movements. In other words it doesn't work if the plugin is not visible, that's not exactly great but it's an improvement. I still can't work out why other third party plugins work with Studio one 5, but not this one. This to me points to an issue with the plugin itself. Allegedly. Yup OBS is the way to go, my video above used that.
As I recall, this seems to be an issue with "mapped" controllers in S1 v5.
S1 works fine using an Arturia KeyLab controller that has an internal CC map for Analog Lab V. No controller mapping in S1 is required for that to work. I realize that's not very helpful at the moment, but is some additional information. Good luck! |
JohnBW wroteAs I recall, this seems to be an issue with "mapped" controllers in S1 v5. Anybody got a list of default CC codes for a Keylab 49? Their manuals aren't helpful. A300 keyboard has custom built in maps. Maybe that's the way to go. Thx
PreAl wroteJohnBW wroteAs I recall, this seems to be an issue with "mapped" controllers in S1 v5. I pulled this from my keyboard using MIDI-OX, then ran the digits through a hex converter (been a long time since I could do it in my head). Then added notes based on this MIDI CC list: https://www.whippedcreamsounds.com/midi-cc-list/ Arturia KeyLab 61 MK II in Analog Lab mode Note: KeyLab 61 MK II Analog Lab mode sends all control events over MIDI Port #1. DAW mode sends control surface events over MIDI Port #2 (MIDIIN2). Captured with MIDI-OX (Hex), a mix of defined and general purpose MIDI CC numbers. These are hard coded in this keyboard mode. Encoders (Hex/ MIDI CC): 1-4A/ 74 Filter Cutoff 2-47/ 71 Filter Resonance 3-4C/ 76 Sound Controller, general purpose 4-4D/ 77 Sound Controller, general purpose 5-5D/ 93 Effect Depth 6-12/ 18 general purpose 7-13/ 19 general purpose 8-10/ 16 general purpose 9-11/ 17 general purpose Faders (Hex/CC): 1-49/ 73 Amp envelope attack 2-4B/ 75 Sound Controller, general purpose 3-4F/ 79 Sound Controller, general purpose 4-48/ 72 Amp envelope release 5-50/ 80 general purpose 6-51/ 81 general purpose 7-52/ 82 general purpose 8-53/ 83 general purpose 9-55/ 85 undefined |
Fantastic thank you so much!
Will try this next week....
Hmmmmm....
I've set up a new Arturia map on my A300 keyboard. All those CC numbers as above are pumping right out. In Studio One I can't seem to find a way to get the CC messages into the Analog Lab V instrument direct, it always goes through my current Studio One A300 mappings under "External devices" which I want to keep for other purposes. How do I bypass Studio one CC mapping so the A300's CC's just squirt directly into the plugin? In Analog V-settings->MIDI area I've just got it set to "generic 9 knobs and 9 faders"/Default right now). I guess I'm expecting the CC's just to work like magic. Thx.
PreAl wroteHmmmmm.... If you run Analog Lab V standalone, do the CC messages from the A300 work correctly when Studio One is eliminated from the setup? What other choices does AL V present to you as a MIDI controller option? Can you select a KeyLab mkII for example? That's what the MIDI messages I sent earlier were based on. |
OK I can kinda get it to work.
It will work provided the control isn't already mapped within Studio One device mapper for A300 (which I need up and running). It won't if the CC number is already mapped in the studio one device mapper for A300. The workaround is to perhaps assign different MIDI channels (say MIDI channel 2 for Analog Lab), so the A300 mapping within Studio One devices will twice as many dials and faders! - a mess - not much logic to it. If only I could just switch off studio one device mapping totally for this A300 device....... Or perhaps I need to create a new external device for the A300, but then it will come up with warning messages - like the midi ports are already assigned - etc... I feel I've either hit a Studio One limitation or my knowledge is flawed (something I'm not understanding)... Thx.
JohnBW wroteIt really sounds like the Studio One external device mapper is interfering with the MIDI messages that should be going straight to the plugin. Exactly right, and I can see that's by design. If only there was a bypassing mapping option... Another workaround would be to remove in Studio One all the A300 device mapped controls, but I need them for the other plugins that don't have this issue. Or just set up entirely different CC's for the A300 for plugins that work via mapping (away from Analog Lab). I feel I'm missing something.
Looks like I'm covering old ground (see link)...
Doesn't look like any great solutions, but there is a solution if I tear apart my current A300 map. viewtopic.php?f=151&t=5342
PreAl wroteLooks like I'm covering old ground (see link)... Agree with that conclusion, unfortunately. Out of alternative ideas... I'm not currently using any S1 control maps, so my Arturia controller messages are going straight through to the AL V plugin on the track. Press a button on the KeyLab mkII to switch over to DAW mode, and the S1 Mackie Control external device kicks in and picks up all DAW control surface messages that go out over port #2, while the MIDI keys continue to be sent over port #1, so no conflict. In Analog Lab mode all messages use port #1 exclusively. As I recall, the A300 used a similar 2-port setup with Cakewalk, but the DAW side setup was a bit more convoluted. |
Thanks....
Well I've got it to work for A300 (it's no more than a workaround) and documented it here: viewtopic.php?p=291277#p291277
Just got a response from Arturia...
Thank you for using Analog Lab V, and sorry for this issue.
Users browsing this forum: DaddyO, JohHuisman and 77 guests
