I recently saw a mixing workflow by a Reaper user and was wondering if it might be possible to do in Studio One. I suspect it might be, but wanted to check here to see if other users have tried this and might have a suggestion. The workflow involves creating multiple master buses for various needs (e.g. instrumental mix, no drums mix, no guitars mix etc...) and the point is to always have these different mixes ready to print at anytime. Post-fader sends are routed from the main buses to the various master buses accordingly. Each master bus has a copy of the same plugin chain as the main master bus. I've sort of been able to mimic this workflow in Studio One however, the main issue is monitoring. In order to do this, I had to go into Song Setup and create a bunch of stereo outputs (not routed to anything) Naturally, I can't monitor the other master buses in this scenario. Is there a better way to accomplish this in Studio One? |
Users browsing this forum: No registered users and 24 guests
