Fat Channel EQ has an issue. After for a while you pick a range (eg. HMF) and adjust it, the EQ range is automatically changed(eg. LMF) even though you don't touch anything.
Too many bugs on 5.5 indeed. Hope they fix the bugs as many as possible before Studio One 6.
Studio One 6.5 Pro Latest ver/ Lenovo Legion 5 laptop/ AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz/ Installed RAM: 40.0 GB (39.4 GB usable) / System type: Windows 10 Pro 22H2 64-bit / GPU: Nvidia RTX 3060 / C drive: SSD 512GB / D drive: SSD 2TB (int) / P drive: SSD 4TB (ext) / N drive: HDD 3TB 5400 rpm (ext) / Speakers: Presonus Eris 4.5 / Headphone: AudioTechnica ATH-M50x / Interface: Presonus Audiobox96 / Microphone: AKG P120 / Midi Keyboard: Korg MicroKey 37 / OontZ Angle 3 Bluetooth Portable Speaker
I have run a test on Win 10 with 5.5.2 and Fat Channel works as expected for me. EQ settings do not change by themselves. I assume you mean the standard EQ as well. I do have the Fat Channel Collection and they all work as expected.
Jemusic wroteI have run a test on Win 10 with 5.5.2 and Fat Channel works as expected for me. EQ settings do not change by themselves. I assume you mean the standard EQ as well. I do have the Fat Channel Collection and they all work as expected. Pro EQ has a different issue. The graphical glitch, but the issue of Fat Channel EQ is different. As I mentioned, it automatically changes the cursor of the range.
I have never seen this. (On Mac and Windows as well) I use Fat Channel quite a lot. Don't assume its a bug. It may be an issue on your system only. Others need to report this as well. They have not as far as I know.
I have never experienced this either. When you say you are using it, after a while, what does that mean?
Studio One Pro 5.5, Studio One Pro 6.12, Faderport 16, Faderport Classic (1.45), Metric Halo ULN-8 MKIV, Presonus Quantum, Presonus Quantum 2, Ferrofish Pulse 16, (2) Digimax DP88, Audient ASP800, BLA HD192, 27-Inch Late 2012 3.2GHZ i5 32 GB 1600 DDR3, 2Tb SSD, 10.13.6 High Sierra + 10.14 Mojave + Windows 10
ianaeillo wroteI have never experienced this either. When you say you are using it, after a while, what does that mean? Say, I cut the HMF around 1db and was thinking what to do next "for a while", and the cursor moved to LMF suddenly even though I didn't do anything with my mouse. It didn't happen at all before 5.5. Every issue I posted recently began to happen from 5.5.
Jean L wroteianaeillo wroteI have never experienced this either. When you say you are using it, after a while, what does that mean? Can you capture this? I'm wondering if possibly (as it could be hidden) that an automation lane is on altering that HMF or LMF range. Just a check is all. Things of this nature rarely move on their own. Worth a check. In the "tracks" column, open it and click all dots on that track to see automation. Also switch your mixer channel below to not "READ" but instead be "OFF". See if it changes when in play at the same location. Edit: typo
Its not really a bug at all. I see it as intended behaviour. In fact with the Fat Channel EQ you only have to hover your mouse over any one of those bands (without clicking) and where ever you are hovering, that band actually gets selected. It's ready to make adjustments.
You are going to have to hover over the band of interest anyway before any adjustment and you will find the cursor just follows you and is ready.
Jemusic wroteIts not really a bug at all. I see it as intended behaviour. In fact with the Fat Channel EQ you only have to hover your mouse over any one of those bands (without clicking) and where ever you are hovering, that band actually gets selected. It's ready to make adjustments. Good call. If it's not that, hidden automation lanes can trip one up, only it would be consistent at those points in time. A slip of the mouse scroll wheel is the most plausible.
Lokeyfly wroteSee if it changes when in play at the dame location. I'd really like to know where this dame location is!
...said Halo
Studio One Pro v4.6.2 / v5.5.2 / v6.6 Serum, Diva, Synthmaster, MTron Pro, Kontakt 6/7, Cherry Audio synths, Battery 4 etc ad nauseam 3XS SQ170 Music Studio PC Windows 10 x64 (22H2) i7 8700 Hexcore 3.2GHz, 16GB, 2TB 970 EVO+ M.2 NVMe SSD + 1TB SATA HD Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, Maschine 3 Beyerdynamic DT990 Pros, JBL 305P II speakers |
leosutherland wroteLokeyfly wroteSee if it changes when in play at the dame location. The local gin mill won't have any respectable dames for the most part. There's a few places, but you're on your own finding them. It's like a good fishing spot. You don't let that stuff get out.
carloschorvat wroteSe solucionó el problema del movimiento en el fat channel? Yo tengo lo mismo y lo que detecté es que los potenciómetros de control del fat channel envían información aleatoria, pues al rozarlos mueven lo que esté seleccionado en ese momento. Translation: (Spanish - English) carloschorvat wrote: "Fixed the movement problem in the fat channel? I have the same thing and what I detected is that the fat channel control potentiometers send random information, because when they are touched they move whatever is currently selected." Sounds reasonable. Thank you Carlos!
Users browsing this forum: No registered users and 68 guests
