What are the advantages to using the pattern editor to write drum and percussion parts as opposed to the drum editor?
IOW, what can the pattern editor do that the drum editor can't? |
https://www.google.com/search?client=op ... 8&oe=UTF-8
If you watch this all the way through (and there are countless others, especially recommend the ones by "Gregor" ) you'll be surprised. They are really unique, even if you don't have any of the ATOM controllers. |
michaelherbert4 wroteWhat are the advantages to using the pattern editor to write drum and percussion parts as opposed to the drum editor? Musicloops. End. Stop. This is a game changer once you see what they can do and "redo" once you start using them. By far the most value added but oddly obscure item I have ever seen in a DAW. Cheers VP
It can be terrific. What I do allot is "convert to pattern" with drum stuff. Now, in midi, I have the input quantize set (yep, I suck timing wise ) but if you convert, you have other options that you don't have with standard midi.
If I had one complaint, it would be that there is no pre-count with "step recording" which isn't what the title is. You do NOT have to "step" things in, it's in real-time recording also. But you have to cycle through I have my ATOM set up that when you hit "setup" there is a control set to "step record" which is nice to not have to use the mouse. I think you can do this on any controller, but not sure. |
Just to add to what I said in another place about Scratchpads, again, when PE first came out, I was overjoyed (well, interested) - but, as with SP, I have never found a need for the PE - and I do a lot of sequenced patterns and what not, a la TD.
But hey, that just me (sidles away into the shadows)
...said Halo
Studio One Pro v4.6.2 / v5.5.2 / v6.6 Serum, Diva, Synthmaster, MTron Pro, Kontakt 6/7, Cherry Audio synths, Battery 4 etc ad nauseam 3XS SQ170 Music Studio PC Windows 10 x64 (22H2) i7 8700 Hexcore 3.2GHz, 16GB, 2TB 970 EVO+ M.2 NVMe SSD + 1TB SATA HD Scarlett 2i4 (G2), Korg Taktile 25, Faderport 2018, Maschine 3 Beyerdynamic DT990 Pros, JBL 305P II speakers |
leosutherland wroteJust to add to what I said in another place about Scratchpads, again, when PE first came out, I was overjoyed (well, interested) - but, as with SP, I have never found a need for the PE - and I do a lot of sequenced patterns and what not, a la TD. si·dle /ˈsīdl/ Learn to pronounce verb 3rd person present: sidles walk in a furtive, unobtrusive, or timid manner, especially sideways or obliquely. "I sidled up to her" Yep, I'm a stinker :p |
reggie1979beatz wroteleosutherland wroteJust to add to what I said in another place about Scratchpads, again, when PE first came out, I was overjoyed (well, interested) - but, as with SP, I have never found a need for the PE - and I do a lot of sequenced patterns and what not, a la TD. Consider my eyebrow raised (since there isn't a smiley for that)
...said Halo
Image, he no show up!
...said Halo
Users browsing this forum: pierregauthier and 127 guests
