When the automation lane is full, the handle is gone, so there is no way to expand it vertically. Is there a way to do it?
Studio One 6.5 Pro Latest ver/ Lenovo Legion 5 laptop/ AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz/ Installed RAM: 40.0 GB (39.4 GB usable) / System type: Windows 10 Pro 22H2 64-bit / GPU: Nvidia RTX 3060 / C drive: SSD 512GB / D drive: SSD 2TB (int) / P drive: SSD 4TB (ext) / N drive: HDD 3TB 5400 rpm (ext) / Speakers: Presonus Eris 4.5 / Headphone: AudioTechnica ATH-M50x / Interface: Presonus Audiobox96 / Microphone: AKG P120 / Midi Keyboard: Korg MicroKey 37 / OontZ Angle 3 Bluetooth Portable Speaker
Thareh wroteOn the left side of the three dots Nope. I already did it, but it shows the automation option instead expanding vertically.
Maybe if you make your song longer it would have some room at the end where you'd get the size bar.
I would take a bunch of those parameters out of there and put them in track automation. https://s1manual.presonus.com/#Automati ... 257C_____5 Some things you need to have in part automation but not everything.
For the actual handle or grip, it looks like your event has just a little more room to move to the right, so the bottom bar could be dragged that little bit more, or the right arrow to it. If you're using a tool such as a line tool and drag, that will move it just enough as well, weather that helps your cause here, I don't know. Just pointing it out. **************** For added tabs selected, the down arrow at far right expand the tabs listing that are in your Instrument automation. (To the right of "RPN Select MSB") That works here. If that doesn't work for you, try Tacman7's advice to run some of those lanes as Track Automation lanes. Only the down arrow should work Otherwise it may be some video or resolution constraint, and you may need to create a ticket.
Tacman7 wroteMaybe if you make your song longer it would have some room at the end where you'd get the size bar. Ok, I'll give it a shot. Thanks!
Lokeyfly wrote. Oh, I just found I can do it on the left side of the automation lane. Am I stupid? LOL Your advice gave me the hint. Thank you!
Awesome, Glad you got it sorted Jean L.
Tacman7 wroteMaybe if you make your song longer it would have some room at the end where you'd get the size bar. Your problem is already solved, but I was just wondering.. I echo the same thoughts as Tacman7 - do you really need all those parameters? Or are they just there "in case of"?
bastiaanmarcscholtemeijer wroteTacman7 wroteMaybe if you make your song longer it would have some room at the end where you'd get the size bar. Oh, I didn't make it. I downloaded a midi file and drag into Studio One, and found there were tons of parameters in it.
Users browsing this forum: No registered users and 30 guests
