I am editing dialog and at times, removing short sections of noise between phrases using Edit-Cut causes Studio One to freeze for several seconds while processing the cut. Using the scissor tool to make two cuts and then delete is fine.
I have a few event envelope gain changes, but only 5 or 6; and have used event fx (Spectralayers Pro 9) on a few clips, but I render each event fx after editing. This dialog track is only around 6 minutes, so it doesn't include hundreds (or thousands) of edits that are common to a full film edit/mix. I considered whether event envelope gain was the culprit, so I tried bouncing events with event gain changes, and the next event gain seemed fine. But after that, the long lag in processing returned with the next edit-cut attempt. Any ideas? A known bug or one that needs to be reported? Due to issues with Nuendo and ARA, I am considering Studio One for some of our dialog editing, but this could put the brakes on that plan. This is on Windows 10, all SSD drives. |
What version of Studio One are you running and have you submitted a Support Ticket yet?
Please add your system specs to your signature (see link in my signature) as this helps us when responding to questions.
Users browsing this forum: No registered users and 85 guests
