Hi have a question in regards to plugin formats.
I have both a Windows PC and have recently bought a MacBook and plan to produce music across both.
I know that AU plugins aren't compatible with Windows so I only want to be using the VST and VST3 type plugins so I don't want the AU plugins showing in Studio One.
As far I know I have the VST plugins in folder path Library/Audio/Plug-ins/VST
I have the VST3 plugins in folder path Library/Audio/Plug-ins/VST3
These are the only two folder paths I have Studio One set to scan for.
The AU plugins are in folder path Library/Audio/Plug-ins/Components which I'm not telling Studio One to scan for but they are showing up in my browser in Studio One.
Can anyone advise please? Thanks.
Specs
Desktop PC
Intel Core i7 7600K 4.0ghz Quad Core
16GB RAM DDR4 300mhz
6GB Nvidia GTX 980 Ti
400GB SSD
2TB HDD
MacBook Pro 2021 14"
M1 Pro 10 core CPU
16 Core GPU
16GB Unified memory
1TB SSD
by Jemusic on Mon Jul 04, 2022 4:08 pm
Open your browser and click on the effects tab. Look top right where the wrench symbol is. See attached image. Note there are under my Cherry Audio effects 3 types of plugins for each effect. The little white dot to the left determines which are seen or not. Uncheck the white the dot next to the AU plugins for example you don't want to see. Click the wrench again and only the white dot plugins will be visible now.
by shanabit on Mon Jul 04, 2022 8:22 pm
Go to your
Preferences/Advanced/Services, Click I promise Ill be careful.
Disable AU plugins support.
Thats what I do here as I don't use AU since Im on PC and Mac here and want to avoid any an all plugins not working or showing up etc.
StudioOnePro 6.1
UA Apollo Twin
OSX Sonoma 14.2
iMac 2013
by mycbeats on Sat Jul 16, 2022 11:21 pm
See the attached screenshot, from the plugin manager you can quickly filter by plugin type and hide them.
Toronto, Canada
Project engineer by day, sound connoisseur by night.
Main Rig: Windows 11 (21H2) 64-bit, Ryzen 3900x, 32GB RAM, RTX 2060, dual 4K Monitors
Presonus 192, Faderport v2, Atom SQ, Akai Advance 49, Keystation 61 mk3, 2x Behringer X-Touch Mini + way too many synths.
Mobile Rig: MBP M1/16GB, Atom SQ, IOstation
Users browsing this forum: SwitchBack and 73 guests
