I'm looking for an easier way to manage (e.g. move, edit gain envelopes) audio events that are stacked on top of one another on the same track. This is for Studio One 5.5.2.
I like to create "manual echoes" where I make two or three copies of a section of an audio event, the move them later in time with gradually decreasing gain on each. I want the echoes to route through the same inserts and sends as the rest of the events in the track. (To make this work, I always have the Play Overlaps option enabled.) The problem is that it gets difficult to manipulate the overlapping events. Even if I manage to move other events to the back, Studio One often picks the wrong kind of cursor for whatever I'm trying to change. I wind up having to temporarily move events out of the way onto other tracks, then back again after I get to the target event. In Sonar/Cakewalk, I would create layers in the track and move the echo events to the layers so I could edit them without any visual overlap. But layers in Studio One are a completely different beast and can't be used this way. I could create a channel bus, move all the inserts and sends there, and move all the automation envelopes there as well. Then create multiple audio tracks routing to that bus, and move the main audio and echo events to these new tracks. But that seems tedious and error-prone, especially moving the automation envelopes (I have eight on the current track I'm having trouble with). I usually don't know up front whether any given track will need this treatment, so I can't create tracks with channel buses to begin with. Any ideas? What's the "natural" way to deal with deeply overlapping events in Studio One? Or is there an easier way to convert an audio track to a channel bus? |
Most just use a delay insert maybe.
You do not have to stay on one track, I use two tracks in similar situation. I've did that with guitar parts that I have trouble getting on one track. If you have the snap setting to event then when you drag an event from one track to the other it would be in the same place. Snaps are good to know: https://s1manual.presonus.com/#Editing_ ... 257C_____1 A snap setting may be what you need rather than two tracks if you read through them and what they're for, maybe what you're looking for... Have you tried doing that with layers? you can move a layer no matter how close to another event cause you've moving it from down in the layers...
erichaarbauer wroteI'm looking for an easier way to manage (e.g. move, edit gain envelopes) audio events that are stacked on top of one another on the same track. This is for Studio One 5.5.2. Hi erichaarbauer, Why not just set up a few duplicate tracks (right click) and place the edited slices per track. You can position the stacked audio events there easily by dragging them (snap on or off) or select event(s) and with the mouse over the bar-beat-ticks in the Track Inspector, scroll with the mouse wheel moving them into the necessary position. I use events the same way at times as a sort of pseudo delay type of effect when called for, and its quite easy this way. The duplcate tracks are auto routed to the same mixer channel. For any other routing needs, create the required tracks to route accordingly. I dont see the channel bus as a solution at all, and as you say, would be tedious. Manual echos are a drop in the bucket in Studio One. Perhaps not how you were used to doing that, but still very easy.
Thanks Tacman7 and Lokeyfly, both suggestions make sense. Much of what I do in this area could probably be done with the Groove Delay on a dedicated FX track. And if I have esoteric needs, duplicating the vocal track wouldn't be CPU-killer it was when I grew accustomed to my current workflow. (An example of "esoteric needs" would include mixing pre-echo with regular echo, as Rush does on the vocals near the end of "Animate".)
The Splitter tool might do the trick, in combination with a few instances of a simple delay. Something similar to what’s discussed in this thread
Users browsing this forum: No registered users and 43 guests
