Is my Melodyne 5.2 Essential working as expected in Studio One 5 Pro?
Posted: Mon Jun 27, 2022 3:07 pm
I'm using Melodyne Essential for the first time (version 5.2) and have some questions about how it is supposed to function. I'm not sure it is working correctly.
1) Create a MIDI chord in Studio One 5 Pro and then Export Mixdown as MP3. See attached image showing a C major chord,
2) Drag the MP3 into a Studio One 5 Pro, select that track, and then hit CTRL-M to run Melodyne
3) In Melodyne go to "Algorithm/Polyphonic Sustain" and let it do it's thing to identify the notes. I know that the Essential version does not support polyphonic. However, it does support polyphonic but only for note identification, not for modification. All I need Melodyne for is to identify the specific notes of a chord in a song that I downloaded.
As you can see in the attached image, the MIDI notes that I entered are for C major. Interestingly, the MIDI notes that Melodyne identifies are higher by one octave and the highest note of the four is shorter than it should be. Not only that, it also identifies some strange notes higher up on the scale that don't exist in my original MP3 file.
So, is this what is supposed to happen? Is it a problem with Studio One 5 Pro? Is it a problem with Melodyne?
Thanks for any answers.
