Is this only me, or someone else as well? It began from 5.5.1 if my memory is correct.
Studio One 6.5 Pro Latest ver/ Lenovo Legion 5 laptop/ AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz/ Installed RAM: 40.0 GB (39.4 GB usable) / System type: Windows 10 Pro 22H2 64-bit / GPU: Nvidia RTX 3060 / C drive: SSD 512GB / D drive: SSD 2TB (int) / P drive: SSD 4TB (ext) / N drive: HDD 3TB 5400 rpm (ext) / Speakers: Presonus Eris 4.5 / Headphone: AudioTechnica ATH-M50x / Interface: Presonus Audiobox96 / Microphone: AKG P120 / Midi Keyboard: Korg MicroKey 37 / OontZ Angle 3 Bluetooth Portable Speaker
SwitchBack wroteYeah, I noticed that too. Needs a bit of on-off to get the graphics working then. I see. Then we should wait until it's fixed. Thx!
It was posted a while back. The Pro EQ curve anomoly was listed as fixed in v5.5.2 (or some interum update after 5.5.0. May have been 5.5.1, based on the release notes. In any event, it did go away.
Are you guys running the latest version of 5.5.2? Several of us verified it went away, but perhaps it's back. I'll check as well tonight.
I've only recently noticed that the glitch is still there, since 5.5.2, the presets load with the correct curve and band settings, but if I bypass a band, i have to mouse click at least 3 times to re-enable it.
In the picture above, the 2.39 k band is enabled but the curve is wrong. I haven't seen that happening after 5.5.2, except when I try to unbypass bands. |
Lokeyfly wroteIt was posted a while back. The Pro EQ curve anomoly was listed as fixed in v5.5.2 (or some interum update after 5.5.0. May have been 5.5.1, based on the release notes. In any event, it did go away. Ye, I'm using 5.5.2, but no luck. I guess they're missing the old graphic cards like mine.
Jean L wroteLokeyfly wroteIt was posted a while back. The Pro EQ curve anomoly was listed as fixed in v5.5.2 (or some interum update after 5.5.0. May have been 5.5.1, based on the release notes. In any event, it did go away. Ok. Thx guys for the heads up. I'll keep watching for it. That said, I'm still seeing occasional stuck (frozen) notes in the note editor, and that was listed in the release notes as also fixed. I see much of that is better now, but there are still traces of the issue still occuring. It's happened to me about three times in the last month.
Users browsing this forum: No registered users and 93 guests
