I just found this issue, and it's really weird. I downloaded a midi file and added it in S1 and added Mai Tai. It didn't make any sound first. So, I changed the preset, and it made sound. However, if I stop and play again, it doesn't make sound again.
I tried it with Presence, and it has the same issue. Thus, I thought the midi file probably causes the issue, so I tried it with a 3rd party synth, and it works fine. It's first time to have this issue. Has anybody had the same issue with me, or just me?
Studio One 6.5 Pro Latest ver/ Lenovo Legion 5 laptop/ AMD Ryzen 7 5800H with Radeon Graphics 3.20 GHz/ Installed RAM: 40.0 GB (39.4 GB usable) / System type: Windows 10 Pro 22H2 64-bit / GPU: Nvidia RTX 3060 / C drive: SSD 512GB / D drive: SSD 2TB (int) / P drive: SSD 4TB (ext) / N drive: HDD 3TB 5400 rpm (ext) / Speakers: Presonus Eris 4.5 / Headphone: AudioTechnica ATH-M50x / Interface: Presonus Audiobox96 / Microphone: AKG P120 / Midi Keyboard: Korg MicroKey 37 / OontZ Angle 3 Bluetooth Portable Speaker
The MIDI file probably contains automation data that Mai Tai and Presence interpret. Go into your instrument part and see if there is part automation for Volume (MIDI CC 7) or Expression (MIDI CC 11).
Lukas Ruschitzka
jazzundso wroteThe MIDI file probably contains automation data that Mai Tai and Presence interpret. Go into your instrument part and see if there is part automation for Volume (MIDI CC 7) or Expression (MIDI CC 11). Or perhaps a program change....(It would be a CC command)
No and no Neither Mai Tai or Presence support program changes. And a program change is not a MIDI CC command.
Lukas Ruschitzka
jazzundso wroteThe MIDI file probably contains automation data that Mai Tai and Presence interpret. Go into your instrument part and see if there is part automation for Volume (MIDI CC 7) or Expression (MIDI CC 11). You were right. Thank you!
jazzundso wroteNo and no Neither Mai Tai or Presence support program changes. And a program change is not a MIDI CC command. Not typically, but it CAN be. A normal program change only supports up to 128 different possible programs, however, to get around those limitations, 2 CCs (0 and 32) can be used to allow you to send bank commands to make the Program Change support up to around 2 million different possible changes. THAT is what I was asking, because if a command is sent that changes to a bank that doesn't exist on the instrument, you might get a nul sound. I did not, however, know that Mai Tai and Presence doesn't even support program change, so those two CCs wouldn't even matter in that case. Gregg "Midiboy"
Users browsing this forum: adamhajrula, SwitchBack, Vocalpoint and 34 guests
