Hello !
I'm kinda frustrated of many GUI lags since I switched to M1 pro MacBook. on native studio one plugins or DAW interface there is absolutely no problems but once I load a 3rd party plugin this is catastrophic ... the whole GUI become laggy like if it was running at 10 fps The issue occur on many plugin but the main one that I notice ( and sadly most use ) is Brainworx ssl 4000 channel strip ... I tried on other daw such as logic and Ableton and I have no issue on these daws . I also tried both AU and VST 3 version but it changes nothing ... If you guys experience these kind of problems and even better if you have a solution for it , I'd love to read you on this subject ! Thanks a lot and have fun doing music |
I had the same issue today using several Opus instances from East West and trying to build an orchestra template in S1. I found switching instruments to be sluggish as well, took a second or more to switch to another instrument, I compared in Reaper and the behaviour was instantly. Not sure this has to do with S1 or the plugins itself but would be great to have some input from other users on this.
louiscoutellier wroteHello ! Fwiw, I just tried putting all the different BX SSL channel strips on a track and couldn't recreate any GUI lag. I'm on a 16" M1 Max Macbook Pro. |
Thanks for your answers !
I'll make a short video to demonstrate the GUI lag So the lag occur even without external monitor on , especially when the sessions are starting to get busy ( I guess when there is many meters displaying at the same time .. ) But yeah when a monitor is plugged in then in increase the lag drastically ... I'll try your tip ! |
Here is the link of a video showing the lag with BX plugin , be sure to watch it in 60 fps :p
I also loaded Soothe 2 to show that other plugins give no GUI issues https://youtu.be/SHMi4lZB31Y |
So can you confirm the behaviour with scaled mode off?
This happens for me too. I see it with various plugins. It's easiest to see with Slate Digital plugins that show a VU meter. The VU meter is very laggy with an external monitor. Without the external monitor, it is perfectly fine. I've tried many things. I don't have scaling, i've tried various refresh rates, etc. M1 Pro 32gb with a 4k external monitor over hdmi (I've tried it over the usb-c ports too).
Anyone of you figure this out? I get plugin gui lag in a brand new session with only four audio tracks and klanghelm VU Meter. I've learned to live with it because sometimes it doesn't lag and I haven't had time to look into it. I got some time now and I don't think an upgrade from the D300 GPU is the solution.
There is a YouTube video about the problems of Apple's GUI scaling of the OS (rather than the UI), and the pixel requirements for Macs (around 220 for Retina, and 1/2 that, i.e. 110 for non-Retina). This means that all 4k 27-32" monitors are out of spec! Notice that Apple monitors are 21.5" at 4k, and 27" at 5k! These are the Apple requirements. The best one can do (if you cannot afford a 5k monitor) is to do the .5 of that, which is a native 2560x1440 monitor (i.e. 1440p or 2.5k, in relation to 5k), and run it natively with no scaling. These are the 2 approaches to solve the GUI lag on external monitors.
Users browsing this forum: edlane1 and 58 guests
