Hello,
how to toggle instrument automation with Behringer X-Touch (MCU)? When I press "Touch" for example the Track automation Touch mode gets enabled: I know that we can enable it via keyboard shortcut after manually dragging the parameter to a track, but it would be a lot faster and more convenient, to just press the Touch Button and start tweaking as it is possible with the track automation (eg volume). Is there a way to sync the state of the Track automation and Plugin(Instrument) automation, please? Thank you very much!
Presonus StudioOne 6, Apple Logic Pro
__ macOS, macMini M1 1TB SSD / 16 GB RAM, MOTU M2, Behringer X-Touch & 2*X-Touch Extender, https://ansolas.de |
What I've done after (invoking midi learn) with my midi keyboard is click on a parameter either directly on the channel or in/on a plugin on the channel.
Then I turn, press or slide a knob which then assigns it there. I see a lot of YouTube videos about the Behringer X-Touch but unfortunatley they're all about the other DAWs. Is it possible to correlate what to do in Studio One by watching one (or a few) of them?
Thank you for the reply!
I know how to assign parameters to the Pots/Faders. I ask how to change the automation mode from the controller for Plugins. (eg read, touch)
bump , no-one?
Not possible ? => https://answers.presonus.com/75226/fr-add-toggle-instrument-automation-with-b-x-touch-mcu?show=75226#q75226
Is there a hotkey slot for this? I've assigned a shortcut, then a controller button to the shortcut for some things in the past.
BobF wroteIs there a hotkey slot for this? I've assigned a shortcut, then a controller button to the shortcut for some things in the past. It is possible via shortcust as i stated above, but thats anything else than intuitive when jaming around. You would first need to drag an drop the desired parameter to a track with the mouse, only after that the shortcut works. That defeats the purpose of a shortcut It would be way more useful if we just could enable touch and tweak the desired parameter and an automation lane is added automatically. That's how it works with a FaderPort 16 btw.
Now possible in Studio One 6 !
Users browsing this forum: jebbyslonar and 68 guests
