Should I use a second drive for S1, songs, files? Are there any benefits to this?
I have a 2tb main drive, should I leave it all for the operating system? |
Hi and welcome to this forum
Well, you can leave everything on your main drive, especially if it's an SSD. If it’s not then make sure that the main drive is a fast spinner (7200 rpm at least). The disadvantage is that audio files tend to get big, so 2GB may seem a lot now but depending how much you record and how you work in S1 that will fill up eventually. Then it's better to have all your S1 user data on a separate drive so that you can simply swap out drives. And it lightens the load on your system drive which is also good. |
Users browsing this forum: No registered users and 38 guests
