nkwainjohnpaulsam wroteI don't use a controller. I simply work with the Piano Roll. That is why I'm wondering myself. or is it due to sample rate?
What instrument? Your issue could be a whole other source of factors. Best to describe it in detail. I see the OP resolved his is, so ok to proceed.
First, list your specs for the most reliable answers. Not that it's crucial here, but the instruments and samples used can often help solve the issue. Thx.
Some thoughts....
Some samplers allow the sample rate to govern the pitch by removing the tuning of the initial or pitch specified sample(s). So that comes back to the pitch change doesn't change on its own (point given, earlier). Typically, it wouldn't be a sample rate issue unless the instrument (of which I don't know which) would allow for it.
You can see where your issue may be then entirely different.
If the samples are from Presence XT, There are some patches that are in another key. So we need to know the issue more clearly.
Side note; (choose a controller)
Check out a Korg Nano controller if table space is an issue. better yet, an Atom SQ to speed up workflow. Drawing notes in a piano roll is all too time consuming. Of course, I'm guilty of drawing many notes in myself.
Pitch issues in general.
You may also want to check any LFO or pitch modulation settings. LFO (Low Frequency Oscillator) are very subtle and can produce such pich variences. LFO's typically have a waver in pitch. Pitch filters are steady depending on the wave envelope drawn. Did you redraw any wave envelopes? Not amplitude envelopes; but pitch. Even a slight change can cause pitch to vary from some sample instrumemts more than others. Check pitch controller settings as well. You wouldn't need a controller to have unexpectedly altered your pitch.
Check the Inspector track under pitch and tune settings. I can't emphasize enough how moving by those fields with a mouse can alter your settings.
Lastly, I'd wring out (remove) all such parts in the song and then listen. Only dont save. Just try to isolate the problem so that in case you saved the patch, it won't come back.
